Sony KDL-50W685A horizontal black lines Pattern
  • Raulnn
    • Nov 2022
    • 103
    • España
    good morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.
    • 12184
    • U.S.
    Don't think the power supply should be noisy, did you check the dc output of it with a multimeter, just put one probe inside and the other on the outside.
    • Raulnn
      • Nov 2022
      • 103
      • España
      Good afternoon! If I measure without connecting to the TV 4.86v
      • PontyPCs
        • May 2016
        • 15
        • United Kingdom
        Looks like a screen data line issue, locate the 8 data lines on the screen driver boards, and using cellotape isolate them, see if that cures the problem, works on most screens in various TVs
          • 12184
          • U.S.
          Looks like it's bad, 4.8, suppose to be 19.5, you might be able to repair it or just try a replacement power supply.
          • Raulnn
            • Nov 2022
            • 103
            • España
            I'm going to do that test, I think it's possible that you are right. but this model is complicated to do this test. It is difficult to access the main board, it is difficult to release the flex, and it does not have an independent tcon, it only has one flex. but I'm going to try. thank you
            • Raulnn
              • Nov 2022
              • 103
              • España
              It could be bad, but I don't know if it can cause those lines. I am going to try what the other colleague says, and if not I will try to buy another external source. THX so much
              • lotas
                • Jan 2016
                • 4597
                • Russia
                The power supply cannot produce 4.8v, if it produced such a low voltage, the TV would not turn on at all, which means you are not measuring correctly or the multimeter is not working.
                First, try carefully cleaning the LVDS connecting cable from the motherboard to the T-con (contacts) on both sides with isopropyl alcohol...
                  • 12184
                  • U.S.
                  The power supply is also not suppose to make any noise, so I wouldn't be so quick to rule it out. Make sure you are testing in dc mode, maybe test another power supply from something else and see what voltage you get.
                  • Raulnn
                    • Nov 2022
                    • 103
                    • España
                    I'm going to start with the easiest thing, cleaning the flex. forgive my ignorance. how do you release it? I have never seen a flex like that. Thanks so much
                    • lotas
                      • Jan 2016
                      • 4597
                      • Russia
                      Try to carefully move the black insert 2-3 mm on both sides with your fingernail.
                      • lotas
                        • Jan 2016
                        • 4597
                        • Russia
                        Or press the white insert and gently pull the train towards you.
                        The main thing is not to damage the cable or connector!
                        • Raulnn
                          • Nov 2022
                          • 103
                          • España
                          I update. I have cleaned the flex at both ends. It hasn't worked. In fact, yellow lines now appeared, some wider than others, until suddenly there was no image left.
                          Of course, I did a correct manipulation, everything turned off.
                          But I discovered something. The noise was not from the power supply, it came from the area of the controller boards, the area where the tcon is integrated. When the lines were no longer visible, and there was no image, the noise disappeared.
                          Could it be a coil in that area in poor condition that is causing the problem? Or could it be some tcon chip?
                          Thanks to all for the help.​
                          • Raulnn
                            • Nov 2022
                            • 103
                            • España
                            hello! could you help me? I don't see the control values ​​for tcon, vgh and vdd. vgl yes I have seen it and it is correct. I don't know if Sony calls them by another name. The TV has TVon integrated into the panel controllers, with a single flex. It is difficult to do panel tests. Let's see if someone can help me continue. Thanks in advance
                            • Raulnn
                              • Nov 2022
                              • 103
                              • España
                              update! I think it's a Tcon problem. The problem is that the tcon is integrated. I would say that the problem is in the DC DC converter circuit. Also, when I connect the TV the integrated DC DC converter gets hot. How can I know if it is the DC DC converter or another element? I have not detected short circuits in nearby capacitors. Let's see if someone can help me diagnose the DC DC converter. I cannot replace the tcon because it is attached to the panel. thank you
                              • Diah
                                • Feb 2013
                                • 6367
                                you have damaged the LVDS...,, so how it come after cleaning it produced yellow line as you stated... use your mobile camera to focus on the contact pins
                                • Raulnn
                                  • Nov 2022
                                  • 103
                                  • España
                                  Now nothing is seen on the screen, only backlight. I haven't been able to damage anything. I did everything following security measures
                                  the pegs are fine
                                  • Diah
                                    • Feb 2013
                                    • 6367
                                    show here clear high resolution photo of both end lvds cable pins
                                    • lotas
                                      • Jan 2016
                                      • 4597
                                      • Russia
                                      Check the fuse on the t-con and see if there is any voltage on the t-con.
                                      • Raulnn
                                        • Nov 2022
                                        • 103
                                        • España
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • dvu0627
                                          Sony XBR65X900H TV with Horizontal Lines right half of screen
                                          by dvu0627
                                          I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                                          I replaced the T-Con board but the lines are still there.
                                          I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                                          Thank you for the help....
                                          02-05-2023, 03:39 PM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
