Samsung UE32F4510 Red led blinking
  • electrocuted
    • Aug 2023
    • 39
    • alban
    Hello, just got this TV not working. The led lights on standby but when trying to power on nothing happens and the led is blinking twice for 5 times. If I get this right, if I remove the cable prom power supply to main board the backlight should light?
    Power supply is BN44-00604F, A5V is present but no switched B voltage. LED driver input is too low, 12V.
  • electrocuted
    • Aug 2023
    • 39
    • alban
    No one has experience on this?
      • 12187
      • U.S.
      "if I remove the cable prom power supply to main board the backlight should light?" So do this and tell results, also post good focused pictures of each board and one of the whole back as to see how everything is connected.
      • electrocuted
        • Aug 2023
        • 39
        • alban
        Ok, there you are:
        Unfortunately my mobile is not that good in pictures... As you can see I tried to ground the power on signal but cannot see voltage than the +5v on power supply.
        • electrocuted
          • Aug 2023
          • 39
          • alban
          Here is the table of pins for the connector power supply-main board
            • 12187
            • U.S.
            Try simple first, unplug tv for 15 minutes, press and hold power button on tv not remote for 60 seconds, release and plug tv straight into wall outlet and try it.
            • electrocuted
              • Aug 2023
              • 39
              • alban
              OK done this, same results!
              • lotas
                • Jan 2016
                • 4598
                • Russia
                What did you think, after this manipulation your TV will work? Check electrolytic capacitors for their capacitance and ESR.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  This is a older set now i think around 2013 like lotas suggests check the capacitors for their capacitance and ESR and maybe also check the backlight leds do the backlights light up with the cable between the power supply and mainboard removed
                    • 12187
                    • U.S.
                    Has worked millions of times and is probably the first SIMPLE thing to try, so drop the smartass remarks.
                    • electrocuted
                      • Aug 2023
                      • 39
                      • alban
                      This was my first question! When the cable was removed nothing lit up but I didn't know if this was normal. Now, could I turn on the power supply with the cable disconnected by shorting ps on/off pin to ground?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        can you check all the voltages like in post 3 of this thread Samsung ue32f4570ss with power supply BN44-00604F - Badcaps
                        I am not sure what pins need to be linked to test this power supply get us those voltages first then hopefully a more experienced member will tell us how to test just the psu output voltages
                        • electrocuted
                          • Aug 2023
                          • 39
                          • alban
                          Done, all voltages are 0 volts except pin 12 (5.2V) and pin 14 (3.3V)
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4326
                            • Italy - Milan
                            to test the psb at bench >jumper A5v + Power on, then apply dummy loads and test voltages, another road is to get a fixed PC power supply and feed the tv with it, 12v & 5v, you will not see the bright image due to BL off but you can test a bit..sound, dark images..​​​
                              • 12187
                              • U.S.
                              It's a samsung ue, pretty sure these have pull-up resistors, so unplug cable from powerboard to mainboard, plug powercord in, if backlights do not come on and stay on, the problem is with powerboard or backlight circuit which includes leds and the connections.
                              • electrocuted
                                • Aug 2023
                                • 39
                                • alban
                                Thanks for the help, shorted pin 12 with 14 (A5V and power on) but all voltages on connector still 0 volts!
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4326
                                  • Italy - Milan
                                  why you posted a partial photo of the p. board? Post at least a link to a good photo, and better also of the soldering side..
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    I have read a thread on this forum where budm metioned on these power supplies the transformer suffers from bad soldering so this may be worth having a look at/re solder
                                    • electrocuted
                                      • Aug 2023
                                      • 39
                                      • alban
                                      BN44-00604F
                                      SAMSUNG POWER SUPPLY BN44-00604F - NETASHOP.GR
                                      • electrocuted
                                        • Aug 2023
                                        • 39
                                        • alban
                                        Measuring the voltage on the 3 large diodes (left side of transformer) I get 5.2V and 17v. It seems that the power on "fails"! Could it be a protection cancelling the power on procedure?
                                          09-07-2024, 05:50 AM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • MtnManMike
                                          Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
                                          by MtnManMike
                                          I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
                                          When I plug the TV in, the screen flashes on and off and...
                                          07-23-2022, 06:43 PM
