Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
  • An-klamm
    • Feb 2023
    • 43
    • Deutschland
    Hello!
    I have a TV that I can't get any further with.
    It is a Samsung UE 55HU8590 with one connect box.
    When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
    As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
    Since the TV works without ocb, I assume that it can't be the PSU?!
    I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
    Is there something elese i can measure?
    I already tried to heat and cool down the mainboards (in the TV and the ocb) but nothing changed.
    I read somewhere that it could be the emmc or eeprom.
    Is there any way I can verify this?
    Especially whether it is the TV or OCB mainboard.​
  • An-klamm
    • Feb 2023
    • 43
    • Deutschland
    I bought a new OCB. Saw that the previous owner had it running. Connected it to my TV and now get sound but still no picture. When the OCB is connected, the background lighting stays off. But even with a bright construction spotlight, no outlines are visible. So it seems that the backlight is off AND no picture is displayed.
    Any ideas?
    • Diah
      • Feb 2013
      • 6376
      at first time you have screen and BL with animation connect to COB., it tell the BOX defect or its cable. but you went to heat the MB and here are your mistake,,,, only you need
      1- with out OCB did you have screen and BL again ? if yes... mean the box or it cable defect..... if NO screen or BL then you did BGA issue on MB during the heating.
      • An-klamm
        • Feb 2023
        • 43
        • Deutschland
        Without the box i still get backlight and animation.
        I only heated up to 40-50°C. I think this should not damage anything.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4339
          • Italy - Milan
          from a previous thread, seems to me a software problem in the main unit cpu board..
          • An-klamm
            • Feb 2023
            • 43
            • Deutschland
            changed main board in TV with one i bought from aliexpress (made a few good expirences with this seller already) but same issue. So only the TCON and Panel are left.
            • lotas
              • Jan 2016
              • 4618
              • Russia
              Did you replace the cable itself with a known good one?
              • An-klamm
                • Feb 2023
                • 43
                • Deutschland
                I replaced it but with one I bought from eBay. So I'm not 100% sure.
                • An-klamm
                  • Feb 2023
                  • 43
                  • Deutschland
                  So you are all informed:
                  I tried another cable and everything works fine again.
                  So in my case there was a broken TV mainboard, a broken ocb and a broken cable.
                  The tv does not work with only one or two of this things replaced.
                  I assume the repairshop the TV was first brought to put all his defective parts in it and told the customer its not fixable.
                  • lotas
                    • Jan 2016
                    • 4618
                    • Russia
                    Yes, most likely this was the case, it is mainly the connecting cable that suffers, since it is very fragile and is susceptible to frequent bends and kinks.
                    • An-klamm
                      • Feb 2023
                      • 43
                      • Deutschland
                      My TV is now running again but I have a defective ocb and a defective TV mainboard lying around.
                      I would like to repair this.
                      I have measured Vdrop on all major components and they are the same, so I think it is a software error. I have read out all winbond ICs with my CH341a and compared the files from the defective and healthy board. The files are exactly the same size and have exactly the same content.
                      there is still an emmc Samsung KLM8G1GEAC-C021 on the ocb.
                      I suspect that this emmc is defective (or has defective sectors). Can I somehow read it out without desoldering it?
                      I have an XGecu T48 at my disposal. But I don't see any pins around the emmc where I could possibly connect it.
                      Is it only possible by desoldering the emmc and getting a suitable adapter?
                      or could it even be a defective RAM (Samsung K4B4G16460-BCMA)? can I test the RAM somehow?
                      Is the RAM replaceable or do I have to program/link it somehow?
                      • lotas
                        • Jan 2016
                        • 4618
                        • Russia
                        Do you have such an adapter for your programmer so that you don't have to unsolder the eMMC, but solder it to the board and read data from it? Have you ever gotten into reading or programming eMMC?
                        https://www.autoecupart.net/products...-3g-programmer
                        • An-klamm
                          • Feb 2023
                          • 43
                          • Deutschland
                          No, I don't have such an adapter. I have one for desoldered emmc's https://a.aliexpress.com/_EIw202z
                          I have programmed various microcontrollers but have not yet done anything with emmc's.
                          If the OCB wasn't so expensive, I would remove the emmc from the good one and give it a try.
                          If someone has the program, then I would unsolder the emmc from the defective OCB and solder a new one on. Can I get this program somewhere?
                          • An-klamm
                            • Feb 2023
                            • 43
                            • Deutschland
                            Is it possible to download the EMMC firmware/software/data somewhere?
                            • lotas
                              • Jan 2016
                              • 4618
                              • Russia
                              Your programmer (T48) supports this eMMC (Samsung KLM8G1GEAC-C021), will it be able to work with it?
                              • An-klamm
                                • Feb 2023
                                • 43
                                • Deutschland
                                ​Thats the supported device list for my programmer. (searched for KLM8G1GEAC)
                                I already ordered a KLM8G1GEAC-C021 (I dont know what the -C021 is for and whether its important or not)
                                I think I'll get around to putting the emmc (the one with -C021) into the programmer at the beginning of next week and see if it basically works.
                                Then I would get back to you and ask again about the content for the emmc.
                                • An-klamm
                                  • Feb 2023
                                  • 43
                                  • Deutschland
                                  So here I am again, reporting back.
                                  Unfortunately, I didn't get to it earlier.
                                  I have ordered a new KLM8G1GEAC-C021 and have been able to read it with the adapter (takes about 10 minutes)
                                  If someone could upload the content for the emmc of a working ocb somewhere, then I would try to unsolder the presumably defective one and solder in a new one.​
                                  • An-klamm
                                    • Feb 2023
                                    • 43
                                    • Deutschland
                                    lotas do you have a dump or can you tell me where I can find it?
                                    • lotas
                                      • Jan 2016
                                      • 4618
                                      • Russia
                                      I'll see where it was from the HU9000.
                                      • lotas
                                        • Jan 2016
                                        • 4618
                                        • Russia
                                        You can read your dump emmc, throw it into the cloud and give me a link, I’ll see if it’s alive or not.
                                          09-07-2024, 05:50 AM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • atkallu
                                          Samsung One Connect Box SOC1001N vs SOC1004N
                                          by atkallu
                                          I am asking have somebody information about Samsung one Connect boxes compatibility ?
                                          So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                                          SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                                          Boxes part numbers are the same: BN68-08730A-00.
                                          07-09-2025, 01:54 PM
                                        • AlexVG
                                          SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                                          by AlexVG
                                          I came across with
                                          SAMSUNG UE65HU8500
                                          ONE CONNECT BN41-02135
                                          Chassis GOLF_UHD_1MP_JACK
                                          TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                                          Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                                          Maybe somebody have an experience with the same issues?
                                          I need your help.
                                          Thank you....
                                          06-08-2025, 06:49 AM
                                          09-06-2024, 11:40 PM
