Sony KDL-65W855C after backlight replacement
This topic has been answered.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i have done many of these KDL-65W855c models aswell as 805c, 850c etc. i replaced the backlights with new after 1 strip was testing dead so just replaced the full array from TVLEDBARZ, i put all the strips in and both sides of the tv are testing 173v per side but tv still gets a brief flash and then 6 red led blink.
    anyone any idea whats going on ? im assuming its not a fault with the new strips.
    i should also mention i have tried swapping both the PSU and AV board from another tv with same model.
  • Answer selected by Mikeyboy2007 at 12-28-2023, 07:18 AM.
    Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok guys i figured it out. there was bad solder joints underneath the PSU on the connectors. i gave them a reflow and some cleaning and they are now fully functioning. i order all my backlights from a well known store in the UK and not from china, too long to ship
    • mmartell
      • Oct 2013
      • 3189
      Six blink IS the backlight circuit though I'm sure you're aware of that...
      I'd say the circuit isn't liking something about your new led strips.
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        I tried it with abother PSU and had the same result.
        • zomi
          • Nov 2011
          • 521
          will bad backlights, one of the strips will not be right ..
          I have had a bad set once..
          So now I aways test them for a short while to see if they are all ok
          also could be a bad connector
          if the tv is open try swapping some out to see
          But from experience I would say a faulty strip
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            I will pop the tv back open and check. But i did test both the left and right strings on LEDs from the back and both where 173v each
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              i have checked each strip individually and as a string and from the PSU side. and they are all fine and hold a steady voltage, i also tested the psu while the tv was power on and backlights connected, even though the backlights do not light up the psu is outputting voltage to the wires and i am no longer getting a red flashing led, possibly becuase the panel is removed ?? any other ideas ? first time ive encountered this problem with these tvs
              • zomi
                • Nov 2011
                • 521
                Only ever had one bad set from china out of 20 or so sets.
                • Diah
                  • Feb 2013
                  • 6657
                  Sony KDL - W serie knowing issue always BGA on Main chip..
                  post photos of yours old and new strips.label / socket also test one LED unit with yours DM in Diode mode to know if there are zener diode build in reserve way
                  • EazyBone
                    • Jun 2023
                    • 1408
                    • United states
                    • Anything I can do with my hands
                    I did not have this exact TV, but yes it's BL circuit it says. It was NOT the backlights when I had it, even though I replaced them. Mine was the PSU for the driver. I would check and post the voltages coming out of it here, does BLerr pin have any voltage?
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      • EazyBone
                        • Jun 2023
                        • 1408
                        • United states
                        Aha! PSU it is. 6 blink not BLs again. Good work
                        • zomi
                          • Nov 2011
                          • 521
                          the well known source will still be getting them from china, lol
                          Glad to here you got it sorted
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • proxneo
                            Sony SW55 - headphone jack replacement - 1-507-806-00 Jack P1
                            by proxneo
                            Dear reader
                            I am looking for a suitable replacement part for the headphone jack for a Sony SW55. The current one often stays stuck inbetween input and speaker mode, resulting in reduced or no speaker volume. Using the regular cleaning tricks didn't work.
                            The part name is 1-507-806-00 JACK 1P (J4 on PCB schematic). Not much can be found on the internet. It seems the green barrel jack part uses 3 THT pins (what I'd expect), to which a separate seemlingly joined grey piece has 6 THT pins. I am making the assumption that the joined grey and green parts are linked, but I am not sure....
                            01-25-2026, 10:31 AM
                          • JohnML1975
                            Sony KD-75X7800F - has backlight but no picture
                            by JohnML1975
                            Hello
                            Started working on this TV
                            Backlight is working
                            There is no picture
                            The backlight changes with what I would assume is the TV boot up sequence
                            I disconnected the two cables between T-CON and mainboard
                            Problem remains the same
                            Next I will remove the speakers and the metal panel covering the buffer boards at the bottom
                            Then see if I can break the problem down further...
                            12-31-2025, 02:17 PM
                          • mc900fthanna
                            Visio M70-C3 LED replacement strips
                            by mc900fthanna
                            So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                            Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                            11-28-2022, 03:03 PM
                          • lti
                            Sony MDR-IF245R transmitter LED replacement
                            by lti
                            I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
                            06-28-2024, 01:47 PM
