Sharp LC-42SB45U No audio, need part identification
  • mu2
    • Oct 2009
    • 217
    I've got a Sharp LC-42SB45U with no audio out on any input. The audio chip is a TDA8933BTW and has been replaced. My scope shows audio at both inputs to the ic, main voltage looks correct. The mute function appears to work.
    The main board in this set is a CBPF82MKP7 and the other number is 715T3252-2.
    The service manuals that I've found on line show the 71T3252-1 main board.
    This set is very close but there is another smd transistor on the bottom of the board listed as Q601. That part isn't listed on the service manuals I've found.
    Does anyone have the service manual that shows my main board or can identify the transistor? I've tried with every magnifying device I have and I just cannot make out the number. I think it's pnp but I'm not sure and it's in the general area of the audio ic. Looks like it's damaged to me.
    Thanks,
    Mike
    Re: Sharp LC-42SB45U No audio, need part identification
    Have you checked voltages on ENGAGE and POWERUP pins?
    ENGAGE and POWERUP must both be >2V to turn it on and produce audio.
    Just so you don't chase a wild goose. Also check for shorted speakers and tweeters. Isolate one channel at a time. Check for good Vcc/Vdd.
    • mu2
      • Oct 2009
      • 217
      Tom,
      I've checked the speakers and both the engage and power up. The power up is over 2 volts and I'm pretty sure I saw a momentary rise above 2 on the engage pin.
      The transistor in question seems to be in that general area. I'd really like to know how it's used.
      Thanks.
      Mike
        Momentary rise on engage isn't good enough, needs to be continuous, so try and see if that transistor might control it, would be odd though, the levels are high enough for MCU to drive directly, can't see why it needs a transistor.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          How about a close up picture of it?
          • mu2
            • Oct 2009
            • 217
            I don't have the time today to take a photo. I assume you mean a photo of the part in question?
            Mike
              And the surrounding area - top and bottom sides.
              • samson7point1@yahoo.com
                Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                by samson7point1@yahoo.com
                The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                The player processes the audio signal using two different reference frequencies. The "R"...
                04-30-2024, 11:22 AM
              • alas3376
                MSI GF76 katana audio ic identification
                by alas3376
                Hi everybody,
                i'm working on this system MSI GF76 with no power and missing sound ic.
                motherboard number: ms-15821
                I would like you to help me finding sound ic's reference or if somebody could share schematic , please.
                Thank you...
                02-20-2025, 02:05 PM
              • i_am_patch
                Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                by i_am_patch
                Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                04-30-2024, 08:20 PM
              • silver60618
                Macbook M3 A2991 Speaker Audio Amplifier IC
                by silver60618
                Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                09-26-2025, 12:25 PM
              • toty79
                Car Audio Delco identification and restoration / repair
                by toty79
                Hello to all friends and welcome back
                I am struggling with a complete restoration of a Delco GM car radio, I have already taken these car radios in the past but this is a bit more complicated and has many problems, in the meantime I ask if anyone knows the exact model in order to trace a possible repair scheme, I have if someone and they have it I would be very happy, I am attaching photos and I also ask what is the purpose of that two-wire connector that comes out from the back (orange-brown) the radio turns on with the display completely off, the mechanics make strange and non-strange...
                09-21-2022, 04:50 PM
