Samsung lnt46A650 bad panel or T-CON ?
  • Maxstang
    • 61
    This is for possible purchase. Opinions on whether it's T-CON or panel?
  • Sevenqi
    • Jul 2011
    • 292
    Re: Samsung lnt46A650 bad panel or T-CON ?
    I would say to Samsung LCD , bad panel is the first possibility, then t-con.
      Panel 99%.
      AFAIK, nobody has yet fixed this problem.
      • Maxstang
        • 61
        Thanks Tom. Seeing more and more of these. Bummer.
        • freakaftr8
          • Oct 2012
          • 3743
          Have a 40 inch. Same symptoms. Run away! Lol
          • MAD hATTER
            • Dec 2013
            • 5
            • usa
            I've got LN46A650 That looks similar but the lines come and go.
            hope it not the panel.
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
              09-07-2024, 05:50 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
