LE40R88BD Black screen with backlight???
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi folks, I have here another 40 inch samsung LE40R88BD which is just displaying a black screen when powered on, I have tested the fuse on the inverter <<<<(t-CON) and i'm getting 13.07DCV on both sides, Is it worth trying the eeprom reset or does this seem like a hardware fault??
    Re: LE40R88BD Black screen with backlight???
    Check the fuse on the t-con with this fault.
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      So sorry... I actually ment to write t-con... thats the fuse i tested.......lol
      • Easky15
        • Sep 2013
        • 285
        • Ireland
        obviously the inverter is fine.. :-)
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          Anyone any ideas what i should test next or is this a faulty t-con??
            Picture of t-con please.
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              here ya go ..
                On the left hand side of the t-con board, there are points marked AVDD_1, 3.3V, VON, VON_P and VOFF. What voltage do you measure on these? Red probe on test point, black on chassis.
                • Easky15
                  • Sep 2013
                  • 285
                  • Ireland
                  Thanks tom66, Hope this info helps
                  AVDD_1 = 15.04DCV
                  3.3V = 3.36DCV
                  VON = 16.3DCV
                  VON_P = 20.9DCV
                  VOFF = 7.51DCV
                    The t-con appears to be working, at least on the power supply front. Try with only one of the LCD panel connectors plugged in (the two ribbon connectors at top.)
                    It is possible it is main or t-con; have you attempted to get sound with an external source?
                    • Easky15
                      • Sep 2013
                      • 285
                      • Ireland
                      Ok done that and with one out i get half a black screen and half white, split vertically right down the middle, Same thing just the other way round when i tried the other connection on it's own.. ;-)
                        Hmm, OK, try with both panel connectors in, and LVDS missing. Full white screen?
                        • Easky15
                          • Sep 2013
                          • 285
                          • Ireland
                          Sorry mate i'm still learning.. What's LVDS,
                            The cable between the main and t-con.
                            LVDS = Low Voltage, Differential Signalling (the type of signal used to transmit video between main and t-con.)
                            • Easky15
                              • Sep 2013
                              • 285
                              • Ireland
                              Ok so i think ive removed the one you are talking about, took a pic to be sure, With this out i just get the same black screen with backlight???
                                I don't know what to make of that but I'm not certain if the fault is on the main or t-con. You can try to connect a source to the TV playing audio, just press SOURCE to switch through them and see if you get audio.
                                • Easky15
                                  • Sep 2013
                                  • 285
                                  • Ireland
                                  Ah ha, Connected HDMI then pressed source button to find it, now the set is switching itself on and off and i hear a clicking relay with the red power led flashing randomly, doesn't appear to be any sort of repeating error code...??
                                    That sounds more like a main board fault than anything.
                                    • Dang
                                      • Aug 2013
                                      • 440
                                      Agreed Tom66, been following this thread and I've just recently suffered a very similar issue with the same Tv, only real difference I saw was a pulsing power supply, this manifested it's self with a flickering back light that would cycle faster then slower and so on, a main board change cured it.
                                      • Easky15
                                        • Sep 2013
                                        • 285
                                        • Ireland
                                        Happy days, I'll order a main board then report back the results when i get it fitted, Thanks for all your help tom and dang... ;-)
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • alro7779
                                          Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                                          by alro7779
                                          Hello, guys!
                                          I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                                          Alex....
                                          10-03-2025, 05:49 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
