samsung picture problem
  • Davezeek
    • Dec 2013
    Hi
    I have a samsung plasma 50' PS50c96hd about 5 years old and just lately after the tv has been on for about 2 hours or so the picture goes off and on intermittently, but I still have sound. I have checked for loses cables etc, and all looks fine in that regard.
    I was wondering if would be some kind of heat related problem, any advice would be great
    Regards
    Dave
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: samsung picture problem
    Tab bonds possibly, try taking each top corner of the set in your hands and gently flexing the tv while switched on... does it reproduce the fault?
    • Dang
      • Aug 2013
      • 440
      Personally I wouldn't try to flex a plasma, glass is inherently brittle so you could end up cracking the screen. To me this sounds like Y-sus board issue, I've fixed a similar issue before by changing some bad diodes but I'm certainly not qualified to give good advice so I'd wait till someone comes along who know's their stuff, Tom66 is a good example.
      • newtothis
        • Mar 2013
        • 1556
        • england
        I meant very gently... I have done it many times without ever breaking a panel
        The warming up period is what makes me think panel... bonds warm and break contact.
        Tom66 is one to listen to mindya, knows his stuff!
        • freakaftr8
          • Oct 2012
          • 3743
          First off lets get rid of some confusion. this us a plasma tv the op has. Is there still sound when this happens? You said it does so im thinking possible sustain board issue or control board. Going to have to take the back cover off for testing.
            09-07-2024, 05:50 AM
          • Rusenga
            Samsung PS43E450A1R Picture Problem
            by Rusenga
            Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
            Note the green light on the tcon flashes every second.
            Power supply board:
            PS on 0v
            Stby 5v
            VS CON 1.72v
            VS ON 3.2v
            VS 208v
            VA. 57v
            X buffer :
            Svt vs 209v
            Svt xout>flactuating between 280 to 900v
            Y main board:
            Svt vs. 208v
            Svt ve. more than 1000v
            Svt yg c More than 1000v
            Svt yout flactuating between 400v and 1900v
            Svt...
            11-24-2023, 09:26 AM
          • KYBOSH
            Samsung UN55MU8000 - Backlight But No Picture Problem
            by KYBOSH
            Hello all
            I pick this up free as a repair project for the holidays.
            The original symptom was power cycling after 3-4 seconds with a single red light flash.
            To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
            I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
            12-21-2022, 12:42 AM
          • Mgiffune
            by Mgiffune
            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
            I ordered a supposedly β€˜new' Tcon board this time, and
            06-09-2024, 10:28 AM
          • Dodgethis
            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
            by Dodgethis
            Hello all,
            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
            09-11-2024, 07:39 AM
