LG 37LB1R lcd tv startup problems
  • anno
    • Sep 2007
    • 140
    • netherlands
    hi. problem with lg 37LB1R lcd tv. i changed power ic and some smd components near ic. now tv has power but problems with starting up. i also changed secundair capacitors , but didn't improve. Tv is starting up, led is flickering, then back off (relay clicking on/off) . The 12 volt is a little bit low, 11.4 volt. the 6 volt line is a little bit noisy (grass).
    the current sense resistor was a little bit black because power ic blowed, but is measure exact the value it should be (i have esr/low ohms meter).
    i don`t understand why the main power supply is going off. is it detecting the 12 volt line is to low or other error. i try heating the mainboard and power supply but doesn't help either.
    i don`t know what to do now. maybe there is a mainboard problem
  • anno
    • Sep 2007
    • 140
    • netherlands
    Re: LG 37LB1R lcd tv startup problems
    i don`t understand where the ripple is coming from. i replaced all caps with low-esr caps. what part can cause ripple too?
    • newtothis
      • Mar 2013
      • 1556
      • england
      Have you tried disconnecting the PSU from the main and forcing the PSU on?
      • anno
        • Sep 2007
        • 140
        • netherlands
        not yet. i can try. then i need to connect the 5v to the ps-on signal
        • newtothis
          • Mar 2013
          • 1556
          • england
          Yes using a 470hm to 1kohm resistor
          • anno
            • Sep 2007
            • 140
            • netherlands
            i tested the psu stand alone and found out the 12v line is low (10.8v). i tried with 12v 0,5a lightbulb as load. there is 400 mA ac on the line. i replaced the caps in the 12v line, but didn`t improve. i am stuck at the moment. why there is ac ripple if the caps are good. i used low esr
            • selldoor
              Slow Learner
              • 7870
              What make series caps did you use and where did you buy them.
              Check for leaky diodes
              • anno
                • Sep 2007
                • 140
                • netherlands
                it is panasonic FC series. The diode is fch10a15 3 legs. is it a good idea to check this diode, out of circuit?
                • selldoor
                  Slow Learner
                  • 7870
                  I really meant the black cylindrical ones - easier to lift one leg of them than wrestle with a 3 legged one. It is the reverse resistance that is important should be infinity. I have been wondering if you could test for ac voltage on each end but dont know if that is a valid test? I will have to resd it up.
                  • anno
                    • Sep 2007
                    • 140
                    • netherlands
                    maybe the PFC circuit doesn`t work. do you know what voltage should be on the big Cap? it's rated for 450volt .
                    • selldoor
                      Slow Learner
                      • 7870
                      Around 326vDC without pfc
                      370 to 400 vDC with pfc
                      • anno
                        • Sep 2007
                        • 140
                        • netherlands
                        ok. i have 335vDC so the PFC circuit is not working?
                        i think this tv has a PFC circuit because the 450V cap
                        ii think i found the PFC IC, marking is 5501A (FA5501A)?
                        • anno
                          • Sep 2007
                          • 140
                          • netherlands
                          The ic is getting power (12v). but i don`t see good output pulses to the gate of FET. maybe the PFC ic is defect
                          • anno
                            • Sep 2007
                            • 140
                            • netherlands
                            I changed the PFC IC and the tv is fixed now
                            • jean luc ferre
                              laptop hp g72 b52sf screen problems
                              by jean luc ferre
                              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                              06-07-2025, 03:27 PM
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
                            • Raven7032
                              Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
                              by Raven7032
                              Hello everyone!
                              Stucked with this problem.
                              Model: Dell G15 Ryzen Edition
                              Board: GDL LA-K454P
                              Symptoms:
                              • Board powers on (consumption ~0.5A), but no boot or display.
                              • Fans spin briefly, keyboard backlight turns on, then fans stop.
                              • Can be shut down via power button (EC active).
                              • No POST, no BIOS splash, no backlight.
                              • Led is blinking 2 orange 1 white
                              • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
                              • No APU_PCIE_RST# - 0V
                              Measurements:
                              • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
                              • EC_RSMRST#
                              06-26-2025, 11:47 PM
                            • gabri2211
                              external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
                              by gabri2211
                              Hi to all 😎
                              I'm looking for any useful information to repair this interface (I have attached the image).
                              On this board I read E3215-1215A_4D.
                              This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
                              If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
                              in particular...
                              11-12-2024, 08:08 PM
                            • vieuxchoub
                              Psu repair: UC3845 not starting up because of NE555 defect
                              by vieuxchoub
                              Dear friends from Badcaps
                              I have been searching for a long time to repair sucessfully a battery charger taking in 230V AC and outputting normally 14V DC. Its power mosfet has been shorted ( Infineon 06N80C3), probably because the bulk storage rectifier capacitor had swollen and had no capacitance anymore and a very high resistance.. The mosfet short has naturaly blown its 0.15 ohms resistor then its driver, the UC3845 IC which was shorted between pins 5 (ground) and 7 (vcc) plus 8 (Vref). Another small resistor surrounding was also dead. So, I have replaced the bulk storage capacitor, the...
                              12-02-2023, 12:56 PM
