Psu repair: UC3845 not starting up because of NE555 defect
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Dear friends from Badcaps
    I have been searching for a long time to repair sucessfully a battery charger taking in 230V AC and outputting normally 14V DC. Its power mosfet has been shorted ( Infineon 06N80C3), probably because the bulk storage rectifier capacitor had swollen and had no capacitance anymore and a very high resistance.. The mosfet short has naturaly blown its 0.15 ohms resistor then its driver, the UC3845 IC which was shorted between pins 5 (ground) and 7 (vcc) plus 8 (Vref). Another small resistor surrounding was also dead. So, I have replaced the bulk storage capacitor, the mosfet, the UC3845, the resistors but my smps was still dead. The vcc voltage powering the UC3845 was under its UVLO on threshold at around 7.8V instead of 8.5 which would have started the driver and the PSU. I have ordered some original (and expensive STM UC3845 IC) with no success and the same startup voltage of UC3845 under its on threshold was still present..... I have tried to change the UC3845 by a more modern UCC28C51 from Texas Instruments with a lower startup on threshold voltage but then my vcc was lower at 6.8V, preventing the mosfet driver IC and the PSU to start.... I have tried to change the mosfet with more sensitive mosfet with a lower Qg value but always with no luck.....
    I have found on my internet search some people having a similar problem without finding a workaround. Some guys were lowering the value of the starup resistor ( originaly in my circuit 94Kohms) to 30 Kohms. But this has not worked for me. I have tested all the capacitors and change some but with no luck. I have looked at my PSU through my infrared camera: the startup resistor was hot and the UC3845 corner of the IC supporting pin 8 and the Vref output was slightly warmer: this pin was powering with 5V the NE555 IC which was timing pin 4 of the UC3845. So I decided to order some NE555 because the overvoltage that had destroyed the UC3845 could have been transmitted straightly to the NE555 IC and this IC seemed to drive the UC3845......
    I have received yesterday my new NE555, I have changed it today and................ SUCCESS
    The PSU was straight outputing 15V, the VCC of my UC3845 was at 17V. The PSU was able to power a 50W car bulb.....
    I hope could help some guys in despair with their UC3845 PSU not turning on after repair
    • Jul 2011
    • 6040
    Good work repairing this battery charger unfortunately you did not say what device it was for which would be helpful for someone who has this device and has these issues
    • vieuxchoub
      • Oct 2017
      • 34
      • france
      Dear Sam
      The UCx84x mosfet drivers family is frequently used in many psu...... Texas Instruments has even given an application note ( U100-A) where they describe a generic synchronisation ( page 10) with an external timer ( NE555), applicable to many circuits..... I have found this problem of UC3845 not starting up because of a low vcc in several forums and videos with different psu circuitry.
      Best regards
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        C(Vcc), the 120uF cap may be bad. If the ESR is out of spec high, it cannot provide the energy needed to start up the UC2842.
        PeteS in CA
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • bendeg
          Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
          by bendeg
          Hi reader,
          I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
          1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
          Output to TRIG of second timer (pin 2) + red led
          2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
          3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
          4) pc fan (12V, 0.18A) in series in drain-source of...
          05-01-2023, 07:59 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
