Vestel!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Vestel!
    Have 11.2 volts from the 5v standby... ESR of cap is good, Resistor checks out... Not sure how the NPN works so would that cause this?
  • Ltank
    • Jun 2013
    • 776
    Re: Vestel!
    It appears that the transistor has a emitter to collector short. I am on my smartphone and I don't have a pen with me to look up the zener diode voltage rating. Also check the voltage across the zener diode if its correct. If wrong value then it may be causing the transistor to be fully turned on. It has a .7v drop across the on junction.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: Vestel!
      11.9v at one side of diode... 0 at the other
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: Vestel!
        Can an NPN be tested in circuit.. if so its bad...
        Base to emitter = red - black _ Closed
        = Black - red _ Open
        Base to collector = Red - Black _ Open
        = Black - Red _ Open
        Emitter to collector = Red - Black = Closed
        I have tested this correctly haven't I?
          Re: Vestel!
          If you have 11.2V into a 5V standby, I'm pretty sure the main board would have fried!!
          • newtothis
            • Mar 2013
            • 1556
            • england
            Re: Vestel!
            Guess what... I didn't lol... Replaced the transistor and voila works lovely :-)
            • Ltank
              • Jun 2013
              • 776
              Re: Vestel!
              I am glad that it worked for you. The voltages told me shorted transistor.
              • newtothis
                • Mar 2013
                • 1556
                • england
                Re: Vestel!
                Assumed it would be as there is very little in circuit to drop the voltage to 5.
                Cheers for your help
                  Re: Vestel!
                  wow, quite surprised to say the least that nothing fried! All functions work?
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Re: Vestel!
                    Yes absolutely perfect! :S
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
                    • Vincenzo2
                      Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                      by Vincenzo2
                      My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                      Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                      I put some pictures here to show that it is labeled "M7"....
                      09-07-2023, 07:43 PM
                    • hobostove
                      Corsair RM1000e - Help identify 5VSB Zener diode
                      by hobostove
                      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                      There's a 22ohm resistor that's melted and open, but it still has the bands.
                      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                      It looks like the diode connects the source and drain of a TNY284...
                      03-27-2025, 02:25 PM
                    • debidoobs
                      Yamaha delay D1500, zener diode broken with no marking
                      by debidoobs
                      im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                      Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                      04-24-2024, 09:01 AM
