LG 60PC1D Z-Sus Shorted
  • Ltank
    • Jun 2013
    • 776
    The Z-sus was shorted. It took a bit of time to carefully remove the
    4921QP1046B IMP. All the SUS_OUT and the VS pins were shorted to gnd.
    The 4921QP1047B was not shorted. Everywhere I check the module was with the heatsink for 90 plus bucks. I found a place in China and got the module for 27 bucks plus shipping for 39 bucks total. I have a Service Manual for this set but it did not include an schematic for the is board. . It will probably take 2 or 3 weeks to come from China. Any body got a Z-sus schematic for theis tv?
  • capkid
    • Oct 2010
    • 1339
    Re: LG 60PC1D Z-Sus Shorted
    I've never seen schematics for these sustains.
    LG Plasma Mal-Discharge Correction Service
    • tiny68
      • Aug 2013
      • 33
      Did you get this TV working. I'm pretty sure I've got the same problem - short to ground on Vs as measured at input connector to ZSUS. Where did you source your IPM?
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
      • modtool
        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
        by modtool
        Hi to all,
        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
        04-01-2025, 08:22 AM
      • BalkanBoy
        Dead Razer Blade 14 2022, shorted CPU?
        by BalkanBoy
        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
        I removed coil and injected 0.7V, it draw around...
        09-27-2024, 12:44 PM
      • barry101
        Apple 820-3662 VCore shorted to ground.
        by barry101
        Hi, Would appreciate some help.
        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
        Get charger light but no fan spin or chime. No liquid damage.
        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
        06-24-2025, 07:34 AM
