Samsung ln46b610a5f Display Issue
    I have the Samsung ln46b610a5f. Got it from my parents. One day it randomly started showing thing red/green/orange lines vertically. It gets worse up to 5 minutes after the TV is on. The picture can be seen. IE, i can see a show or whatever is on. Sound is great. I changed out the main board, T-con board, and inverter board. None of which helped. I have not tested the power board or anything? Help? I can send pictures soon.
    Re: Samsung ln46b610a5f Display Issue
    If switching the T-con and Main didn't fix it then you are looking at a bad panel.. sorry
      That really sucks, is there any TV that has a comparable Panel for cheaper?
        The pictures were just taken today. That black screen was taken switching between channels.
          mine does same exact thing, frustrating, cant find a panel anywhere
            Bad panel. Not yet aware if anyone has fixed this fault. It seems like it would be something temperature sensitive, but could be a leaky gate driver pulling the VGH/VGL low. In which case not fixable.
            Too many damn LCD panels dying!
              I tried pulling the whole thing apart and pulling the panel out but that's a bigger job than I'm comfortable doing. Guess I'll just sell the parts on Ebay.
                I have something similar going on with a Samsung 40 inch I've got these vertical smears along with the colors smearing vertically on the left side of the screen spanning over to the right past Center it would appear that is temperature sensitive as when the panel is cold it's much less noticeable I have tried free spray on every component inside television and no avail but one time I freeze the whole panel and the picture came back perfect it doesn't have anything to do with the drivers on the top one side of the screen it seems to be more in the middle believe it or not. I think it is some kind of contamination issues within the liquid crystal layer. lol I guess it would make good TV if you live in the freezer
                  I just read somewhere that a couple guys used hot guns, or hair blower? and that helped the glue reseal itself. *shrugs*, I might have a go at it with my wife's hair dryer
                    There is no glue. The top ribbons are fused into the panel and sometimes there is a silicone barrier for protection. Has no affect on the workings of the screen. Heat is probably not going to do the trick. Freeze spray should. But give it a shot anyway. Just be careful not to heat too much in one place you can make matters worse for good.
