Samsung ln46b610a5f Display Issue
  • jshlnd14
    • Dec 2013
    • 6
    I have the Samsung ln46b610a5f. Got it from my parents. One day it randomly started showing thing red/green/orange lines vertically. It gets worse up to 5 minutes after the TV is on. The picture can be seen. IE, i can see a show or whatever is on. Sound is great. I changed out the main board, T-con board, and inverter board. None of which helped. I have not tested the power board or anything? Help? I can send pictures soon.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung ln46b610a5f Display Issue
    If switching the T-con and Main didn't fix it then you are looking at a bad panel.. sorry
    • jshlnd14
      • Dec 2013
      • 6
      That really sucks, is there any TV that has a comparable Panel for cheaper?
      • jshlnd14
        • Dec 2013
        • 6
        The pictures were just taken today. That black screen was taken switching between channels.
        • lnlkustomz2007
          • Aug 2013
          • 11
          • usa
          mine does same exact thing, frustrating, cant find a panel anywhere
            Bad panel. Not yet aware if anyone has fixed this fault. It seems like it would be something temperature sensitive, but could be a leaky gate driver pulling the VGH/VGL low. In which case not fixable.
            Too many damn LCD panels dying!
            • jshlnd14
              • Dec 2013
              • 6
              I tried pulling the whole thing apart and pulling the panel out but that's a bigger job than I'm comfortable doing. Guess I'll just sell the parts on Ebay.
              • freakaftr8
                • Oct 2012
                • 3743
                I have something similar going on with a Samsung 40 inch I've got these vertical smears along with the colors smearing vertically on the left side of the screen spanning over to the right past Center it would appear that is temperature sensitive as when the panel is cold it's much less noticeable I have tried free spray on every component inside television and no avail but one time I freeze the whole panel and the picture came back perfect it doesn't have anything to do with the drivers on the top one side of the screen it seems to be more in the middle believe it or not. I think it is some kind of contamination issues within the liquid crystal layer. lol I guess it would make good TV if you live in the freezer
                • jshlnd14
                  • Dec 2013
                  • 6
                  I just read somewhere that a couple guys used hot guns, or hair blower? and that helped the glue reseal itself. *shrugs*, I might have a go at it with my wife's hair dryer
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    There is no glue. The top ribbons are fused into the panel and sometimes there is a silicone barrier for protection. Has no affect on the workings of the screen. Heat is probably not going to do the trick. Freeze spray should. But give it a shot anyway. Just be careful not to heat too much in one place you can make matters worse for good.
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
                    • Cooperr
                      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                      by Cooperr
                      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                      10-21-2025, 01:11 PM
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                      Samsung 9 NT900X5L Notebook Specification for Upgrade or Repair
                      This specification for the Samsung 9 NT900X5L Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NT900X5L boardview and NT900X5L schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung 9...
                      09-06-2024, 05:33 AM
