Philips 42PFL7603D Losing brightness
  • anotherdude
    • Feb 2013
    • 488
    Friend is having problems with this set apparently parts of the screen lose brightness and go dim, sometimes it works fine and then goes like this and other times it's like this from start up.
    Power problem?
    sorry for the poor picture
    Re: Philips 42PFL7603D Losing brightness
    Panel tab bonds, sometimes repairable.
    • sordids999
      • May 2013
      • 2157
      sorry to hijack this thread but did you ever fix your problem
      got this set today where one side seems to be ghosting images and dark
        Definitely looks like a tab bonding fault...
        • Ta91Ko
          • Apr 2023
          • 3
          • Slovenija
          Hello, did you manage to repair the fault? I think I have the same problem.
            • 12206
            • U.S.
            Probably a backlight issue, 15 years is a pretty good run for those leds.
            • Ta91Ko
              • Apr 2023
              • 3
              • Slovenija
              Don't think it is backlight problem due to image retention...
              • lotas
                • Jan 2016
                • 4668
                • Russia
                This model does not have LEDs.
                To begin with, distort the LVDS cable, carefully clean the contacts on this cable.
                  • 12206
                  • U.S.
                  Oops, my bad, it was one of the first with ambilight tech, but i shouldn't have assumed it was led backlighting.
                    • 12206
                    • U.S.
                    Probably poor tab bond contact, many have been "fixed" with shimming.
                      • 12206
                      • U.S.
                      Something that you can try is take your knuckle and tap on the bezel NOT the screen, tap all along it, see if the display ever changes any, like clears up for a second or anything.
                      • Ta91Ko
                        • Apr 2023
                        • 3
                        • Slovenija
                        I tried the knuckle test, you were right. The screen does clear for a moment. Looks like it is bad tab bond contact. Is it possible to repair it?
                          • 12206
                          • U.S.
                          Here's a shim job done on a sanyo, he does all of them, I was lazy and just did the one that wasn't getting good contact but its working fine, I guess all the trouble it is to tear down, might as well do them all, there's a bunch more videos on youtube about the procedure, some use flexible tubing and such, just need something that's going to keep a little pressure on it for good contact and not damage it of course: https://www.youtube.com/watch?v=purk_SyiT44
                          • ohren
                            Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                            by ohren
                            I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                            The setup is basically:
                            Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                            Transistor is switching the 3.5 V supply on the power board....
                            12-05-2024, 11:10 AM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
                          • dr.thodt
                            HP Pavilion 15-1812nd scrren brightness issues
                            by dr.thodt
                            I have a notebook, HP Pavilion 15-1812ND with brichtness issues.
                            When in windows, I use the the brightness keys on the keyboard, brightness goes up aprox (75%) then the screen begins to flicker and gets darker again.
                            When I lower the brightness again it's getting brighter first and then it dims and the flickerings gets less.
                            I already chaned the screen and LVDS Cable.
                            Does anyone ever seen this problem and maybe have an idea how to fix this.
                            Any help would be apprecited.
                            Thank you
                            09-24-2024, 04:15 AM
                          • double_DD
                            Philips curling iron - is this a common AC cable?
                            by double_DD
                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                            08-18-2025, 10:04 AM
                          • janos6662000
                            Philips 47PFS7509/12 LCD TV problem
                            by janos6662000
                            Hi
                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                            I downloaded original firmware and applied the update, but the problem remained.
                            From a colleague i received a "factory package software" which is a lot bigger.
                            I made another firmware update, but still did not solve the problem.
                            Somewhere on the way the error got worse, because at the moment the...
                            08-12-2025, 12:54 PM
