Panasonic Viera G20 54in. W/ A Board From 50in?
  • photoeye
    • Dec 2013
    • 8
    I need to replace an A Board on my Viera G20 54 inch Plasma and have been holding out for a decently priced part. A really good deal popped up in my area for the same set in the 50 inch model and I was thinking about buying it to harvest the part. The part numbers are very close and upon closer inspection the boards themselves look identical in every way. Does anyone know if the 50 inch board will work in the 54 inch television?
    Thanks!
    Re: Panasonic Viera G20 54in. W/ A Board From 50in?
    It should be fine, as long as they are both 1080p and both have same features (e.g. cannot use 3D board in 2D set.)
    • Hombre
      • Jul 2013
      • 231
      • Croatia
      Sry, but i will hijack your thread
      Can i install a D board from 42G15 to my 46G15, will it work? Board number is same for both.
      • photoeye
        • Dec 2013
        • 8
        Thanks! I may take a chance on this. Anyone else want to chime in?
        • freakaftr8
          • Oct 2012
          • 3743
          I recently swapped a 55 inch tc-p55ut50 3d smart mainboard into a tc-p50u50 non 3d or smart tv. . This tv uses the same panel as its brother the tc-p50ut50, which is the same just a smaller version of the tc-p55ut50. The a board and ss boards were bad so I swapped in the 55 inch 3d mainboard and its ss board works now with 3d and smart features. Of course I had to modify the back for the added lan connector and made room inside the tv for the bluetooth dongle to interface with the glasses.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
