SAMSUNG UA46D5000 T-Con Board
  • dlink377
    • Nov 2013
    • 5
    • Indonesia
    I have a SAMSUNG UA46D5000PMXXD LED TV that have black screen issue. The sound and the backlight works fine. I know the boot up perfectly because the sound can be heard and the TV is listed on SAMSUNG remote control app on my phone.
    I called my local TV repair shop, they took a look and determined that the T-Con Board is failed and need to be replaced. After 1 month, they found a matching T-Con board and replaced it. The TV works fine after that repair, though few black lines on the screen (about 1/3 the screen length) appear on the below, but not a big problem for me.
    But, after 1 week, the TV went black again. The issue is same before changing T-Con board. I can safely assume that the T-Con board fails again and need to be replaced.
    Don't want to pay additional expensive T-Con board again, I decided to find the T-Con board myself on the Internet. I found that the T-Con board that have exactly same like my TV is expensive and need to be shipped from Europe countries.
    However, I found some almost same board on the Chinese TaoBao website. The T-Con board only single character different with my panel. The one available of the website is LTJ460HN01-H, but mine is LTJ460HN01-V. Are those board compatible with my TV? Link. I don't mine few small line appear, as long don't fill my screen and bright colour.
    I believe the 1 character difference is the region. Like UA for Asia, UN for North America, etc, but not quite sure of it.
    One more thing, I want to know, why my replacement T-Con board fails after 1 week of usage. I assume that the T-Con board already fails before replacement, but I am not quite sure of that. If I replace the T-Con board again, I fear that the replacement will fails again.
    I uploaded some picture here. I didn't notice anything burned out in the TV.
    My Panel : LTJ460HN01-V
    My (Replaced) T-Con board: LSJ460HN01-S J460HN01-0F S100FAPC2LV0.3
    Model: UA46D5000PMXXD
    Version: HQ01
    Thank You
  • freakaftr8
    • Oct 2012
    • 3743
    Re: SAMSUNG UA46D5000 T-Con Board
    Are there heat transfer pads in place for the IC's on the tcon board? Some ics overheat if there is no cooling for them.
    • vinceroger69
      • Mar 2012
      • 6714
      theres a white fuse on the tcon board does that test ok you might have to refit into tv power on set and test voltage each side of the fuse.
      • dlink377
        • Nov 2013
        • 5
        • Indonesia
        No, there isn't any pads on the t-con board IC.
        I remember the original t-con also didn't have any pads.
        I have 4 others identical (only different size) tv that doesn't exhibit the t-con board failure. Maybe this is just unlucky batch of tv.
        The one with 125V/3A text above?
        How to test it? I have Analog Multi-Meter. I assume the red (+) goes to either one of the metal parts of the fuse and the black (-) goes to where? Or just like a car, the body (metal parts) is the ground?
        I only have basic knowledge of electrical hardware (more a software guy). I am truly sorry because asking so basic question.
        • vinceroger69
          • Mar 2012
          • 6714
          yes thats the one can you set set your meter on ohms and touch each side of the fuse red on one side black on the other.never really used a analogue meter sorry.
          • dlink377
            • Nov 2013
            • 5
            • Indonesia
            Thank you for the reply.
            I already checked the fuse, it is about 2 ohm. I also check others fuse in the power supply, it is nearing 0 ohm.
            Cannot give accurate result because I'm using Analog Multi-Meter, I will buy DMM if I got time to electrical store.
              A few thin black lines at bottom -- was TV ever water damaged?
              • dlink377
                • Nov 2013
                • 5
                • Indonesia
                As far as I know, there is no water damage.
                The black lines appear after changing the T-Con board.
                But, I am also not 100% sure the black line appear after the TV T-Con board fail because the TV is seldomly used.
                • alltvrepairs
                  • Jan 2014
                  • 219
                  • Malta
                  Have you solved this issue. Have exactly same problem. Found exact same part on taoboe site but not sure if these are oroginals or some chinese clones.
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • ohren
                    by ohren
                    09-08-2023, 05:24 PM
