Panasonic Plasma TV TX-P50X50B - Shorted power supply
  • tri-comp
    • Denmark
    #41
    Re: Panasonic Plasma TV TX-P50X50B - Shorted power supply
    OK, I see no-one's interested.
    However, just in case someone ends up here from a Google-search or the like, I'll give some feedback on how this has ended.
    Obviously replacing the original 7-pin FAN6755U with a new 8-pin ditto wasn't an option.
    It seemed more reasonable trying out the NCP1271 chip even if I haven't found any docomentation as to this chip being a drop-in replacement for a FAN6755U.
    Not really surprising as the pin-out is different from the 6755U EXCEPT on the Darfon schematic.
    So, here goes nothing and I replaced the original chip labelled 6755U with a NCP1271B and switched-on.
    Everything is absolutely fine and the TV works again.
    Testing for bad-cap's, just in case showed nothing.
    I assembled the set and called it a day
    Thanks again for the Darfon PSU schematic.
    • freakaftr8
      • Oct 2012
      • 3743
      Wow nice fix! Looks like it was the standby controller all along?
      • tri-comp
        • Denmark
        #43
        Yes, it certainly seems to be the only thing wrong.
        The fault started out being periodic with typically a week or so between breakdowns.
        Finally the fault matured and stayed permanent.
        So, it wasn't such a big thing finding the defective switching-chip.
        It was identifying what could be used as a replacement that proved difficult.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
