Dynex LCD TV, no backlight. Suspect transformer ohm readings
  • DasBub
    • Nov 2013
    • 15
    Hey guys. I have a cheap-as-chips Dynex 22" TV ( DX22LD150A11 ) that powers on, passes the flashlight test (image on dark screen), but with no backlighting.
    The power supply board is a DPS-65TP-2 A and - after looking through the forum - I suspect the culprit is a transformer on the secondary side, T302, part number TMS94481CT.
    This page lists the resistances as 0.2ohms primary and 960ohms secondary. The values I've measured are [S1-S2] 267Kohms and [S3-S4] 980ohms.
    I'm guessing this means that the transformer is toast but I just wanted to make sure I'm not insane.
    Thanks!
  • DasBub
    • Nov 2013
    • 15
    Re: Dynex LCD TV, no backlight. Suspect transformer ohm readings
    Derp. Should've included model number in thread title. Sorry about that.
      Yes, that is bad winding on the transformer.
      • DasBub
        • Nov 2013
        • 15
        Thanks for the sanity check! I'll order a replacement and let you know how it goes. Cheers.
        • RWolfe8970
          • Oct 2014
          • usa
          I have the same TV as you however mine is saying please wait, Im thinking backlight inverter after doing some research any thoughts
          • Amraks
            • Nov 2011
            • 725
            "please wait" sounds like its trying to load firmware.
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
            • triplefour
              TCL 75S421 has sound but no backlight not even a flash
              by triplefour
              TCL 75S421
              PSU BOARD: 40-L402H8-PWD1CG
              it shows not even a flash of backlight when powering up.
              but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
              testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
              unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
              i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
              with mb connected, PSON...
              11-17-2023, 09:54 PM
