vestel 17IPS06-2 help
  • Sparks88
    • Sep 2011
    • 110
    Re: vestel 17IPS06-2 help
    ok thanks will get one and post back.thanks again
    • Sparks88
      • Sep 2011
      • 110
      Hi, still trying to resurrect this set, bought a backlight tester and all the backlights work when tested individually so i am back in the same boat, its becoming an obsession now with a determination that i wont be beaten, trying to find a suitable bulb to test the board "live" but i cannot make my mind up as to a suitable one, any help appreciated.
        Use the neon bulb on each output to see if it is working.
        A backlight tester isn't necessarily going to help - the TV may determine a failed bulb differently to your tester.
        • Sparks88
          • Sep 2011
          • 110
          tested aech output with a bulb and when i connect the bulb to pl700 and pl701 in turn the set stays on, when its connected to pl702 and pl703 it goes 2 secs to black, now i am getting excited lol.
          • Sparks88
            • Sep 2011
            • 110
            pl700 and pl701 are fed by the same transformer which was replaced because the original one was o/c, heres hoping that tom66 might get a chanc to jump back onto this thread.
            • Sparks88
              • Sep 2011
              • 110
              #26
              Just gonna bump this to try catch tom66, hoping that its not a backlight problem but something on the protection circuit side, because when either of the backlights is replaced with a bulb the set does not trip.Could the new transformer be bad?? and not be able to drive the old backlights??
                Yes, the new transformer could be bad. One way to eliminate a specifically located protection fault would be to swap the two transformers. If the fault moves, the transformer is probably bad.
                • Sparks88
                  • Sep 2011
                  • 110
                  #28
                  thanks, gonna check around fan7311 because all the feedback for overcurrent run to pin 10.
                  • Sparks88
                    • Sep 2011
                    • 110
                    #29
                    Sparks88 =1
                    vestel = 0
                    sometimes when you look at something it can be staring you in the face and you cannot see, the set is working after i took a step back and started retracing what i had done with help from tom66.
                    original fault 2 secs to black
                    opened back cap missing on decoder board replaced still no go
                    general resolder job and cap testing still no go
                    then tom pushed me in the right direction with the check windings of transformer found one open circuit, replaced but still no go.
                    decided to do a general component check around the safety circuit and tom said try swapping around the new transformer i did and the fault followed the new tranny, easy new tranny faulty WRONG
                    Hooked up scope component tester and started comparing one agains the other and it was the older tranny which was faulty, all i can think is that when the first one went open circuit the other was probably going the same way but was weak instead which then put a mismatch load on the feedback circuit and caused the set to trip out.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • hazi12
                      Vestel main board 17MB140TC
                      by hazi12
                      Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                      Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                      I can send a dump....
                      10-01-2025, 01:28 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
