vestel 17IPS06-2 help
    I need the schematic for a vestel board 17IPS06-2 290108 which has main board 17MB35-4 060109 any help appreciated, the main board on mine is slightly different to others i have seen in that it has a cap 22uf 6v by the top 5 pin connector (used for programming) and 3 hdmi sockets, i am getting the infamous 2 seconds to black, checked all voltages and the only thing on the power board (nearest schematic i could find) is the 5v standby is low at 4v, everything elas seems to be within .5v of spec, andbody who has experience of this board please feel free to add a comment or 2, thanks in advance
    Re: vestel 17IPS06-2 help
    No doubt Tom has come across these boards!
      the power board is 290708 and not as i wrote above, there are 2 caps where normally you would find a large 400v type and the voltage across the pos leg is approx 230v dc and it doesnt change when the set is switched on and only changes by 3-4 volts
        Have seen one in a 24" Technika. Caused by one of the inverter transformers failing open. Common fault.
          thanks tom, will check and let you know.
            spot on, tr701 o/c, dont suppose you know where i can get a IVE8001CL transformer from in the uk?
              Can only find overseas... ~£18 inc shipping
                thats more than the sets worth considering the probable faults that will occur in the future, oh well time to start looking for a scrap panel on the fleabay (got one its mine) thank you for all your great help.
                  I've only ever found them from that location in Spain. I regularly sell 26" ish and 24" Full HD sets around £80 to £100 here, no problems. Hardly think a £20 investment is a waste.
                    Yeah I was thinking the same to be honest, I sell a lot of 22" monitors and get around £60 - £70 so for a bigger set it's worth it
                      i didnt think it was worth it but maybe you are right.
                        absolutely crazy postage prices from spain
                          Right followup, got the new tranny but still the same problem, any more pointers, i will do a few more voltage check but getting the right manual is a nightmare.
                            Still test open? Or now about ~700 ohms?
                              hi, both trannys measure 674 ohms in circuit
                                OK, do you get any backlight, even just a brief one?
                                  yes after a few seconds the backlight flashes then goes to black
                                    Check all bulb connectors, no bent pins?
                                    Do you happen to have a neon bulb?
                                    This can be used to see if any of the transformers are not working.
                                      dont have a neon bulb is there any other way?
                                        Not that I'm aware of, but I can find neon bulbs on ebay for a few pounds each.
