Phillips 42pfl3603d/f7 No Picture
  • landyboy
    • Apr 2013
    • 443
    Just picked up a Phillips 42pfl3603d/f7. Backlights come on but no picture, 12v to TCon both sides of fuse. Any thoughts main board?
  • landyboy
    • Apr 2013
    • 443
    Re: Phillips 42pfl3603d/f7 No Picture
    Here are some pictures of the boards.
      I would check the VCC and VCC1.8 test points on the t-con. VCC is likely 3.3V.
      • landyboy
        • Apr 2013
        • 443
        VCC is .890VDC and VCC1.8 is 0
        • landyboy
          • Apr 2013
          • 443
          Correction VCC1.8 is .543VDC
          • landyboy
            • Apr 2013
            • 443
            Both of these are low. Are these voltages supplied by the regulator on the TCON itself?
              They are supplied by that small square chip to the right of the larger LG Philips chip.
              Next, check AVDD; this is across the two small capacitors marked C111, C112 near the bottom middle right of the board.
              • landyboy
                • Apr 2013
                • 443
                11.68vdc
                • landyboy
                  • Apr 2013
                  • 443
                  Suspect Bad Tcon?
                  • landyboy
                    • Apr 2013
                    • 443
                    Ok I replaced the TCON with a "good" one off of ebay. I now have a picture but it has horizontal flickers as seen in the picture. Most of the research I did still points to a TCON. Do you think this TCON is bad as well?
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Possibly a bad board... That's problem with eBay
                      • landyboy
                        • Apr 2013
                        • 443
                        Ordered a different TCON same problem. Could a bad main board cause this?
                          Possibly. A panel problem could also do so.
                          • Fly_Among_Stars
                            VIZIO E70-E3 Half picture with half TCON
                            by Fly_Among_Stars
                            I have a VIZIO E70-E3.
                            Symptoms: Black screen, no picture, but LED backlights are working.
                            I probed the power board and voltages are as listed on the board.
                            Main board appears fine, too.
                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                            There are two separate ribbon cables feeding the LCD.
                            If both are connected, the screen is black.
                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                            04-24-2023, 08:20 PM
                          • shelby5041
                            Samsung LCD TV no picture backlight on no 12v at tcon
                            by shelby5041
                            hi
                            i have a samsung lcd tv
                            it powers on with sound and backlight but no picture
                            all voltages from PS are good 12v 3.3v and 5v
                            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                            no 12v at the tcon fuse
                            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                            the odds of having 2...
                            10-08-2021, 08:21 AM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
