Sony kdl-40ex500 no power
  • Bob Neely
    • Oct 2013
    • 41
    I picked up this TV today from CL. He said he has been trying to fix it for the last 6 months. He tried replacing the power supply and it didn't fix it. He had a repair place look at it and they piggybacked a fuse onto the main fuse. (Kind of cheesy). That didn't fix it. He also gave the repair place the other power supply board and that main fuse was blown. They said it would be a signal board. (Not sure what a signal board is, maybe the main board???).
    I plugged it in and there is nothing. No LED light on the front, no relay clicking. I am getting 170 vdc out of the bridge rectifier. I am also getting 3.3Vdc coming out of a couple of the pins and 2.7 vdc on the top right connector on the power supply.
    I would like to verify that it is a main board before I spend the money. I will take pictures soon.
    That is all I have for now.
    Thanks for any help.
  • Bob Neely
    • Oct 2013
    • 41
    Re: Sony kdl-40ex500 no power
    here are some pictures of the power supply and the main board.
    • Bob Neely
      • Oct 2013
      • 41
      I received a main board today and it didn't fix it. I did a closer look at the power supply and found C6332 charred. Can anybody help with the value of this capacitor and if there is another one on the board that is can use for this cap. I have another power supply that has the same problem. Thanks for any help.
      PS: I need to apologize for the "cheesy" comment in post 1. I tried to replace the main fuse earlier and could not get the fuse out of the holder. I had to solder another fuse to the top of the old.
      • NathanGJedi
        • Aug 2011
        • 10
        Same exact problem with the charred cap. Got a full rebuilt kit including the millipede-looking IC from ShopJimmy and shows NO power (before it would blow the fuse every time). Any ideas?
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
