Sharp LC-15B4U-S need cord
  • Jim1590
    • Jul 2013
    • 98
    Got this as part of a lot. Missing power cable. Amazon has one for the cheap price of $100.00............... umm no.
    http://www.amazon.com/SHARP-ADAPTOR-.../dp/B001DPPCRW
    Any ideas on how to jury rig it? Looks like DC 12v 37w with a special square connection.
    Here is the part number for the cord: uadp-a009wjpz
    Bear in mind, I have not yet been able to determine if anything about this TV is actually working. Baring any ideas on how to do this cheaply, gonna toss it unless someone wants it?
    Re: Sharp LC-15B4U-S need cord
    A little 15" TV? They are worth about £5 where I come from.
    You could probably replace the square connection jack with a round one, if it has the same solder footprint.
    • Jim1590
      • Jul 2013
      • 98
      OK, I will play around with it before junking it. Thanks
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        somebody is smokin some good shit thinking anyone will pay $100 for that adaptor.
        should be easy to rig up something to fire it up.
        its a $ 50-$75 video game monitor here.before atsc so got to have a stb to play it as a tv.
        i have one here with some fancy designers name on it i have to do the same with.its got a round 8? pin.
        • Jim1590
          • Jul 2013
          • 98
          Square 10 pin.
          And to think they won't share what they are smoking either.
          Probably going to move onto the next one for now. Need to finish on a toshiba posted here and have a 7 red light phillips plasma leaning against a wall I am staring down. The last phillips plasma kicked my butt $ wise before I gave up.
          • advant
            by advant
            02-03-2020, 12:25 AM
          • gavenb
            Sharp LC-80LE661U 80 inch
            by gavenb
            Hi folks!
            I have a LC-80LE661U that had some interesting issues.
            Initially, it would come on and show the sharp logo and would show normal static before shutting off.
            I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
            11-12-2023, 02:05 PM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • Stefan Steff
            HP Elitebook 840 G5 strange behaviour, need ideas...
            by Stefan Steff
            I finished my work for this year, so I'm free until January 6th.
            My last task it's unresolved and I'm looking for ideas for the return in January.
            So what's about...
            This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
            My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
            No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
            The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
            12-24-2024, 05:50 AM
          • Ritchie_Uk
            Sharp 32BC2K0 Service Manual of Fix Please?
            by Ritchie_Uk
            Hi Folks
            I am searching for a Sharp 32BC2K0 Service Manual
            Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
            Fault - Coloured "Bars" very thin all across the screen.
            I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
            I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
            Is there such thing as a Boardview for this TV?
            I will Post the Photos in a second
            Stay Safe !...
            09-05-2024, 06:35 AM
