52 kdl-52w5100 picture problem
  • Mongor62
    • Sep 2013
    • 83
    • California
    TV is a Sony 52 kdl-52w5100,
    This is my buddy's TV and he thinks i can help him so what they hey. The TV works in every way except the bottom 3/4 of the screen has a slightly distorted picture along with ghosting but it fades from right to left? I know he had the TV like this for a while and sent it my way when that 3/4 of the screen went completely black and he couldn't get it back on til he brought it to me?
    He has 2 T-Con boards and both show the same picture so i don't think that is the problem but i could be wrong, i tested the power going to the T-Con board and it reads 12v like is should according to the power supply labeling.
    I have searched forums, images, you name it i cannot find anything like this so any help is greatly appreciated.
    The pictures aren't great and they all show the same thing but i wanted to show a few examples of it.
    Re: 52 kdl-52w5100 picture problem
    Do you see double images when you put up the user menu on the screen?
    • Mongor62
      • Sep 2013
      • 83
      • California
      Nope, I also did a factory reset, check for update it said it didn't need one & had the TV do a self diagnostics and nothing.
      • Mongor62
        • Sep 2013
        • 83
        • California
        This line that fades is in the same spot even if i change the aspect ratio could this be the main board?
        • tibimakai
          • Jan 2012
          • 3680
          I have found one on craigslist-Inland Empire a couple of weeks ago, but that one had that three quarter screen all black and only the upper portion had a good picture.
          I have asked then, but nobody has answered.
          • tibimakai
            • Jan 2012
            • 3680
            I'm wondering, it can't be that the side tabs causing this issue? There are no burned marks on those tabs?
            • Mongor62
              • Sep 2013
              • 83
              • California
              I am not sure because the schematic i found i can't quite understand how to take off the front bezel to look at those tabs but i did a small flex test with my hands and cold sprayed it and nothing
              • coobmsusa
                • Mar 2014
                • usa
                Mongor 62,
                Did you ever find out what was causing your 2/3 screen issue on your Sony 52 kdl-52w5100?
                I also have the same issue with the same model. [/B][/B]
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Post pictures with the problem and with the menu up.
                  • doorzon
                    AOC AGON AG273QCG refresh problem picture shifts
                    by doorzon
                    hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                    The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                    See attached picture.
                    I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                    However, this could also be related...
                    08-12-2023, 02:36 AM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • retrorepair
                    SONY KDL-40P3600 Picture Problem
                    by retrorepair
                    Hello gurus, hope you can assist me...
                    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                    Thanks in advance.
                    10-11-2024, 05:12 PM
                  • Rusenga
                    Samsung PS43E450A1R Picture Problem
                    by Rusenga
                    Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
                    Note the green light on the tcon flashes every second.
                    Power supply board:
                    PS on 0v
                    Stby 5v
                    VS CON 1.72v
                    VS ON 3.2v
                    VS 208v
                    VA. 57v
                    X buffer :
                    Svt vs 209v
                    Svt xout>flactuating between 280 to 900v
                    Y main board:
                    Svt vs. 208v
                    Svt ve. more than 1000v
                    Svt yg c More than 1000v
                    Svt yout flactuating between 400v and 1900v
                    Svt...
                    11-24-2023, 09:26 AM
                  • Chrissygizmo
                    Linsar 75uhd520 picture problem
                    by Chrissygizmo
                    Hi all, I've recently acquired a linsar 75uhd520 TV, there was nothing on the screen when I first got it, now after finding around I've managed to get a picture but it has loads of lines running through it, I've uploaded a Google image of what the picture looked like, i will upload photos of it soon, also, I didn't get a remote with it, I've went through all my remotes trying to get one to work it but had no luck, does anyone know what remote would work this set please??...
                    01-24-2023, 10:20 PM
