Apex ld3288m - No power, nothing
  • DLinkOZ
    • May 2013
    • 238
    Before I start digging around in this thing, has anyone come across these TVs showing absolutely no signs of life? Worked fine, sat for a few months, hit the power button and nothing. It's very simple internally, just a power supply and the "main unit" as they call it. I see no visible fuses, no apparently faulty components.
    One odd thing is that when I plug it in, some lamps in the room and on the same circuit flicker slightly.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Apex ld3288m - No power, nothing
    May be a bad primary cap that's not bulging or leaking.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • DLinkOZ
      • May 2013
      • 238
      That's my guess, even though everything looks good. I have to buy some caps for something else, it's a cheap gamble to just replace the small number of caps on this power supply just to make sure.
        A good start is to check power supply output voltages: if they are bad, further troubleshooting can be done, but otherwise it may be a main board (=main unit) fault.
        • DLinkOZ
          • May 2013
          • 238
          Checking the power supply output:
          1st 5v - 5.2v
          2nd 5v - 2.9v
          12v - 12.2v
          24v - 22.2v
          One of the 5v is nearly half down, and the 24v is quite low. I'm going to pull the board back out, and see if I can follow the traces back to see what differentiates the two 5v outputs.
          • DLinkOZ
            • May 2013
            • 238
            Clarification - 5vsb is 5.2v, 5v is 2.9v
            • notallbad
              • Oct 2012
              • 1190
              try taking the readings with the power supply disconnected from main board, is the 5v still reading 2.9v?
                You may have bad capacitors on the 5V and 24V lines, or excessive load on those.
                • DLinkOZ
                  • May 2013
                  • 238
                  Without the main board, I believe I was getting *only* the 5vsb. The power button routes through the main board and then triggers the power supply. I did trace the 5v (that reads 2.9v) back to a cap that seems suspect using the old unreliable test method (continuity one way to see resistance go up, then swap leads and watch resistance go down then back up again, it's OL one direction and works the other). I know, not a good test but definitely doesn't look right and there are a few caps that act like that. I cataloged all the caps last night and will replace them all, just in case.
                  • DLinkOZ
                    • May 2013
                    • 238
                    I recapped two TVs' power supplies today - another was an LG and it's back up and running. This one, however, no change. 5vsb and 12v still look good, 5v and 24v are still low. I don't have the original remote, but programmed the only code that my DVR's remote says works for Apex Digital LCD sets (just in case the power button is faulty) and still no-go.
                    Any input as to further testing? The idea of excessive load bringing down those rails seems like it may be on the right track, as I mentioned earlier sometimes when I plug it in it causes a quick flicker of the lamps on that same circuit.
                    • DLinkOZ
                      • May 2013
                      • 238
                      The main board, CV318H-X, seems to be widely-used on Westinghouse and ProScan sets. Just trying to get as much potentially useful info as possible.
                      • DLinkOZ
                        • May 2013
                        • 238
                        I may just grab a replacement main board, they're very cheap. Does anyone know if there's anything that differentiates those for a Westinghouse from one for an Apex? Same part number for the board, but want to make sure there isn't something strange that's done per-manufacturer.
                        • DLinkOZ
                          • May 2013
                          • 238
                          So after some time away from it, I decided to take another quick peak at this thing. Something that strikes me as odd:
                          Without the main board connected, I get 1.4v on the 5v, 12v and 24v. 5vsb is fine, which I would assume is proper. If I connect the main board, I get the previously-mentioned out-of-spec voltages. But I shouldn't at this point, right? I haven't hit the power button, or otherwise turned it on however the main board *seems* to be invoking a power-up of the power supply. Or could this be simply due to the super-simple design of the TV (two boards main and power, power also has inverter hardware) and its components?
                          The power supply has only 6 connectors - input mains from outlet, 2x output to the backlighting, and the three connectors pictured that go to the main board. My question, so I can see if the power supply is simply not outputting proper voltage or if the main board is dragging it down, is can I force the power supply to power on without the main board connected? That way I can read power output without any load.
                            You can force on the power supply board by itself by using 1K resistor between STB (PS_ON) pin and the 5VSTBY, the connector has to be removed so it will be pulling down the STB pin.
                            Can we see the picture of the whole board? We need to find out if it has PFC Voltage booster circuit or not.
                            • DLinkOZ
                              • May 2013
                              • 238
                              I put a 1k resistor between the first two pins on the far left in the picture above (labeled STB and 5VSB) and there was no difference - 5V, 12V and 24V all stayed at 1.47v. But they do go up if I connect the main board (at 5v - 2.9v, 12v - 12.2v, 24v - 22.2v). Here is the full power supply.
                                That STB may be active LO, if that is the case, check the DC voltage at STB pin when TV is OFF and when TV is turn on. Also check the DC voltage on the two legs of that large 450VDC filter cap when TV is OFF and when it is ON.
                                The 5V low but the 12v is OK, then I would look further in the 5V rectification and filter section, or it may be loading down by the main board.
                                • DLinkOZ
                                  • May 2013
                                  • 238
                                  That's the oddity, it won't turn on. The 5VSTB always has 5v, regardless of connectivity to the main board. However, when I connect the main board I get voltages (though some are out of tolerance). Hitting the power button does nothing. I'll check the voltages and report back.
                                  • DLinkOZ
                                    • May 2013
                                    • 238
                                    Large cap never reads more than a few hundred mv, simply a few hundred mv negative on the negative lead. Like I said, it doesn't respond to the power button, so I have no idea what it would do in an ON state. At this point, I'm trying to determine if it's the power supply not putting out enough voltage (see the 12 and 24 volt readings above) or the main board dragging them down. I think those would be my only two scenarios, due to the simplistic nature of this TV.
                                      The 5VSTBY is the always on power supply, it will be present when the the TV get the 120VAC to it, it is used for running the micro controller on the main board. When the power switch or Remote power on is activated, the main board will send the PS_ON to turn on the rest of the power supply section.
                                        "Large cap never reads more than a few hundred mv" That large cap should have about 165~170VDC on it when the TV is plugged in, it cannot be in mV otherwise the 5VSTBY will not be working at all. Recheck your measurement, you have to measure it right at the two legs of the cap.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
