which is the eeprom on samsung BN94-00963E main board?
  • CDNJay
    • Nov 2013
    • 7
    pasting my question from the other thread someone started from a slightly different tv. I just need to know which is the eeprom if someone knows.
    hey Guys, Im new to posting but have always found my answers here and never really need to post after searching. Now i need to post. Like the OP here I am having similar issues but with a samsung LCD LNS4041dx/xxa. replaced the caps that were bad and power supply is giving all correct voltages so I suspect the main boards eeprom needs a jump. But with all the 8 leg chips that look similar on both the front and back of the board i just cant seem to figure out which one to jumper. most from what I have read say to its the chip reading 24cxxx on the back of the board. Only chip I have with 24cxxx anything printed on it is on the front of the board about an inch above the usb service connector. Am I safe to assume that this is the eeprom? Main Board number is BN94-00963E. Any Help would be greatly appreciated
    Jay
    Re: which is the eeprom on samsung BN94-00963E main board?
    LN-S4041 service manual
    http://elektrotanya.com/?q=showresul...oria=&kat2=all
    • CDNJay
      • Nov 2013
      • 7
      That is a great resource to have thanks so much budm but I am more confused now. the eprom location on the guide is not what is on my board anywhere that I can find.
      i have several 8 legged chips but only 1 labeled "atmel 630 24c256bn su18" the others have wp numbers so can I assume this is the right chip. it is located at IC203 on the front of the main board (the guide says it is located at ic112 but i dont have a 112 anywhere that I can find)
      • CDNJay
        • Nov 2013
        • 7
        well beiung A.D.D. and inpateint as I am I decided that I would go ahead and try jumping what seemed to be the only chip that was labeled like an EEprom...after some difficult soldering of a jumper wire (i really wish my hands were steadier) i fired her up cut the wire after a second and she fired right up right back to the regular input she was left on when she died. all settings even seem to be the same.
        For anyone that is looiking for the info, the EEprom on this board is at location IC203 about 1 inch above the usb port that is used for servicing the tv.
        Thanks again budm as without that manual I probably would not have risked doing this at all.
        cheers guys.
          Glad to hear that you got it figure out, I myself never run into the EEPROM problem yet, lucky me.
          BTW, which pins are needed to soldered the wired too?
          • CDNJay
            • Nov 2013
            • 7
            I did pins 5 and 6
            • mmartell
              • Oct 2013
              • 3189
              Where is the thread about this so I can read up on this anomaly ?
              • Dang
                • Aug 2013
                • 440
                Hi, right here: https://www.badcaps.net/forum/showth...055#post389055
                • mmartell
                  • Oct 2013
                  • 3189
                  Originally posted by Dang
                  Thanks for that !
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    Today, 08:34 AM
                  • Lee M.
                    Samsung UN75RU8000FXZA bad main board?
                    by Lee M.
                    When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                    11-08-2023, 07:46 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
