Problem I am having is the tv will not turn.i noticed the sc board light will light up then it will dim out.and I lose my 15 volts.does this sound like a short on sc board.
Panasonic tc-p50c2 sc board
Re: Panasonic tc-p50c2 sc board
When it fails to turn on do you notice any power light blinking or such? If so, count the blinks between each pause.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Like Tom asks, blink code? The C2 series SS boards seem to short out , Check for shorted Vsus line on TNPA5072 SS, Q001,Q002,Q021,Q022 short, RJP30E4 IGBTs.
Could be SC, need more info.
https://www.badcaps.net/forum/showth...light=tc-p50c2Comment
Usually if SC LED lights up the MID ERC voltage is good so it is sustaining the panel at least briefly, unlikely to be dead short SC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yeah, I'm expecting SS most likely. Too soon to call. Could be a number of things.
Massive electrical storm here 3am, yippee. Who needs sleep?Comment
You may have a bad panel. Try repeating the test but with each ribbon going to the panel isolated and C boards both connected. If it doesn't die then power off, connect some ribbons randomly, repeat until you isolate the failed one. If one is failed, the panel is toast, unfortunately...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
