Re: Panasonic TH-42PX70B Blowing mains fuse.
Thank you both. So fitting the 0.22ohm ones i have found could cause problems. But i am wondering if they would be good enough just to determine whether this thing is going to go into meltdown again once i have replaced the known faulty parts? Once i know that is not going to happen, then i would not mind waiting a few weeks for the correct value to arrive from the far east. I have searched a lot of places in the UK, and 0.22 is the closest i have found. I have indeed even tried looking for them in an axial package, but no luck there either.
With regards to D415 and Q404, no shorts. Normal sort of diode drop reading from D415, and similar sort of readings from Q404, but nothing even close to a short. The only known problems in that part of the circuit are R439 and R493.
IC406 is something i am wondering about, seeing that R439 and R493 go down to pin 7 of that chip. I also notice that one of my blown ceramic resistors - R448, also connects to that chip via pin 6. (GND).
Talking of which, pin 6 of that chip (IC406) is show on the schematic to be 'GND', but i have looked for continuity between that pin and one of the pcb ground points (ground to chassis), but am not getting continuity. What ground would that pin be connected to?
