Panasonic TC-P50G20 Problem
  • sprocket
    • Jul 2009
    • 47
    I'm trying to help a friend fix a 50" Panasonic TC-P50G20 Plasma TV that gives the 10 code when plugged in
    This is my first time with a Plasma and don't fully understand what board does what
    I have gathered some good info on it and tried to pin down which board is bad by using their procedures and things don't seem to happen the way they explain it
    I also have taken voltage readings from various places and have those
    I could use some help getting the right board at the price they cost
    Thanks in advance
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G20 Problem
    A little light on info. Explain what you have tried and your results.
    Most likely though is shorted Vsus on the SC board, that's the most common fault and the buffer boards may be shorted too and will need checking.
    Like most Panasonic SC boards they're scarce to find at times, you're definitely going to pay what they cost and not cheap at the moment unless you have component level fault finding and soldering of small component skills.
    i have repaired three of these boards yet to see anyone else have a go and also repair there's . A few have started but did not come back with any results.
    I assume your SC is TNPA5081AF , these too will work TNPA5081AP, TNPA5081AW not that improves what's for sale but at least you know if any of these pop up you can use them.
    • sprocket
      • Jul 2009
      • 47
      Correct it is a tnpa5081af
      first plugged in I get 2 clicks and then the 10 code
      unplugged P2 to SC and P11 to SS and still 10 code
      unplugged P35 from PB with the 2 above still unplugged, still 10 code
      checked vsus and vda for short to ground and found them not shorted
      I have a flash of the 15v on pin 7 of P6 and 15v from drain of Q355 and 100+ on P2
      These are very brief and then shuts off
      I might add that the green leds on both SC & SS light a little and the fade out
      • tw2005
        • Oct 2011
        • 6458
        Try disconnecting SC20 ribbon from the SC
        • sprocket
          • Jul 2009
          • 47
          10 code
          after the 2 clicks and shut down, if I press the power button should I here a click (relay)?
          I don't
          • tw2005
            • Oct 2011
            • 6458
            This one could be A-board. I'm thinking of suggesting disconnecting all flat ribbons from the A that go to the C boards and the SC, all power from the SC & SS, disconnect the power that feeds the c buffers, disconnect anything connected from the SS to the C board.
            If still 10 A-board would be a real possibility but there may be a flow chart to follow.
            If the 5V is shorted that can trigger 10 blink too.
            I have done the above on a 2010 HD model to prove the A-board and under this conditon It simply powered on. No display of course but took the opportunity to measure the PSU which was all good.
            Have not done it on this model though.
            • tw2005
              • Oct 2011
              • 6458
              Have you got the Service manual?
              Also this is a generic list from a training guide for SOS10
              Abnormalities of the F+15V.
               Reasons:
               The P board is not generating the F+15V
               SUB Voltages are affected by the K board or by
              metal object present in the SD card slot..
              Shorted Vsus (By the SS board or SC board).
              Shorted Vda (By the panel, or any of the C board)
              Wrong diagnostic by the A board.
              • tw2005
                • Oct 2011
                • 6458
                Try this guide although 42" it's FHD and same generation,
                Just following what you said it sounds like you may be following the flow chart anyway?
                • tw2005
                  • Oct 2011
                  • 6458
                  I've got a TNPH0893 out of a US GT25 same panel and boards otherwise. Not sure how close it will be to your 0834 for onboard comparison??
                  Can't hook it up though, I don't mess with mine now, MRS don't like me messing with it for testing anymore.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Originally posted by sprocket
                    10 code
                    I don't
                    Not sure, when mine shuts down after a couple of minutes the relay clicks. That's normal shutdown with the remote into standby.
                    Mine is set to last state if the power fails so with the master on if it blacked out, when power resumes it auto starts. If it was off at the time in standby, it would remain in standby.
                      That is normal behaviour for Panny's, I think they do it so they can download a DTV guide update or firmware update over the air if there's one available, my PZ80 clicks on about once an hour for 20 seconds to do this.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Really, I know if I'm silly enough to stay stuck on this forum into the wee hours of the morning mine does that for an update at 3am. never realised it was hourly but then it's on when we're home so that'd be why I only notice it whenn all is quiet.
                        • sprocket
                          • Jul 2009
                          • 47
                          I tried undoing ribbons etc and power won't stay on, still 10
                          I have what I could find for a service manual. but with all the revisions etc, I'm sure they are accurate
                          One walked me down to disconnect A1 and asks if it shut down with a 10, that removed power to the K board blink led so I had no idea
                          I'll check out the 5v tomorrow and let you know... thanks for all your work
                          Yes I have that manual and tried to follow the chart but just does not calculate
                          • tw2005
                            • Oct 2011
                            • 6458
                            I would hardly call it work. pretty boring sitting here with nothing to comment on . Anyway not sure how much more I can help but I can say that I induced a 10 blink caused by the A-board when the 5V line was shorted by a couple of octal buffer ICs. Blew them twice to get sos 10. Long story but was a very bad TV with corrosion and shorting SC20 ribbon.
                            That was SOS10 with everything disconnected but don't get your hopes up it's the same but maybe elsewhere.
                            • sprocket
                              • Jul 2009
                              • 47
                              Thanks again tw2005 for your help
                              I'm reporting back on the results
                              Even though I had the brief 15v etc. the digital never had time to reach full readings so I spaced it off as that
                              I done some more checking and jumping and found what I thought was a bog down (just couldn't produce the amperage) in those voltages, so I ordered and got a Power Board and BINGO that was it
                              • tw2005
                                • Oct 2011
                                • 6458
                                good result considering the A board would have been impossible to find. Don't see too many PSU issues either normally.
                                • SpinMaster12
                                  • Jan 2016
                                  • 5
                                  • Usa
                                  For my TCP50G20, I have verified that all of my components are good, however the last SC board I put into the TV blew out. Could the actual plasma panel possibly be responsible for shorting the SC boards? And if so, is there anyway to test the panel itself?
                                  • Borghi
                                    • Feb 2016
                                    • 9
                                    I have a TCP50G20 that has 4 blinking lights. According to what I have read, it is probably the P board, but may be the A board. Any suggestions on how to pinpoint the cause??
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Most likely SC board, stick to one thread otherwise all the replies will be scattered
                                      • GuyTV
                                        • Apr 2014
                                        • 7
                                        I must stress the fact that the TNPA5081AP will not replace the " AF ".
                                        The SC41, SC46,& SC42 are made different. They don't fit on the SU & SD boards. If one wants take a chance in interchanging those connectors, you can try that. I have bought a "AP" to replace a defective "AF" , but I don't want to try the interchange. I will not risk blowing the SC board I just bought.
                                        Interchanging the connectors might work. It's at your risk.
                                        It is almost impossible to find a reliable seller for a "AF" board.
                                        I will rebuild the the two bad "AF" that I have here. I did a couple B-4 with success.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • hugocarmo
                                          Panasonic TX-24A1UN CRT Sound and Input problem.
                                          by hugocarmo
                                          Hi.
                                          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                                          It is imaculate inside, almost no dust or debris inside.
                                          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                                          So I started to look for a service manual, I found one, and started from the beginning.
                                          Most of the times the caps are the problem so I orderer all the caps for all boards,...
                                          04-26-2025, 07:45 PM
