Funai LC320EM2
  • Ltank
    • Jun 2013
    • 776
    Funai LC320EM2
    The set was dead. F601 125v 4 amp fuse blown. Q600 a K10A500 mosfet was shorted. in the primary circuit. I tried to cross reference to no avail.
    could not find a data sheet to get specd to cross it the hard way. Does anyone know general purpose replacement? Could not get the correct service manual either. Anyone? Thanks!
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Funai LC320EM2
    https://www.badcaps.net/forum/showth...t=25477&page=5
    it is k10a50d not 500 try tk10a50d to find it at digikey or mouse or ebay
    • freakaftr8
      • Oct 2012
      • 3743
      Re: Funai LC320EM2
      Check zener diodes in the hot section as well. Most likely shorted one or two.
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
      • csmith
        Funai LC3200SSx Shutting Down
        by csmith
        This set won't power up with alternating green and red power light.
        Forced chassis on all voltages are correct except all 6V. It measures 28v.
        on cathode of D661. Anode measures 6v. Mainboard is BA94F0102 4_a.
        Schematic I'm using LC320MEM9 which is not close enough. Any suggestions
        from the Funai experts. Thanks!
        01-25-2023, 03:39 PM
      • connorcc2005
        Thermistor specs and cross reference
        by connorcc2005
        I'm getting some conflicting information and thought I'd toss it out to all of you for input.
        What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
        The physical diameter of the piece is 5.1mm measured with a caliper.
        Other than what you see in the pic, there is no other writing on the part.
        My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
        06-16-2022, 04:16 PM
      • raregtp
        Voltage regulator cross-reference
        by raregtp
        Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
        The first is:
        A1
        AS1117L-18
        B0640 25
        The second is:
        A1
        AS1117L-33
        B0640 28
        I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
        If anyone can assist...
        03-15-2020, 11:12 PM
      • JDC
        (SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
        by JDC
        Issue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
        Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board.
        02-01-2022, 10:25 AM
