What is an EH14A 737J58?
  • Dang
    • Aug 2013
    • 440
    Just been trying to fix an LG 37LC55 and found that this component is faulty, after about 10 minutes of being on an assortment of horizontal lines appear on the screen, this then leads to colour haloing, colours going weird, even the sound can cut out if a big bang happens(that would be GTA4). I found if using cold spray directly on the component that the lines would go, it will still leave the haloing, colour distortion etc but the lines do go only to return as the component heats up again, pressing the reset button on the main board will clear the haloing and colour distortion. I did try re-soldering it and this seemed to help extend it's usability but only by a few minutes, so it would need replacing, I just haven't a clue as to what it is so if you can help, that would be great, thanks, Andy.
  • killian6pk
    • Apr 2010
    • 502
    Re: What is an EH14A 737J58?
    Post a good clear picture of the component and mark it on the board. Also give us the Part Number of the board it is on and the Model Number and brand of the tv the part is out of.
    I tried running different variations of the number you gave and none hit for a datasheet.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    • Dang
      • Aug 2013
      • 440
      Hi, sorry, it's from an LG 37LC55 main board. I've just had a good look around and found this, it seems it's a 1A low dropout linear voltage regulator AZ1117, SOT-223, 2.5v: .
      • killian6pk
        • Apr 2010
        • 502
        Ok, do you have a DMM?
        If so set it to DCV and place black lead on a ground screw and red on each of the legs in turn. Report readings back here. Number pins 123 left to right with large flat tab at top. You are reading voltages so boards need to be powered up. Be very carefull around the board where the power input is. Try not to touch anything on the power board.
        Those regulators are frequently bad. They are pretty easy to replace. There is a thread that talks you through testing and what to expect. I will try and find it and get back to you with the address.
        • killian6pk
          • Apr 2010
          • 502
          This is the location of the testing info for the LDO Regulators. Read it before doing anything. Also have you done a search of your model # in this section. You will get a lot of good information just by reading other peoples posts and the solutions they found.
          https://www.badcaps.net/forum/showthr...999#post300999
          Hope you get it repaired.
            So it is the 2.5V fixed regulator, looking at it with the big tab up (same as the pin 2 middle pin), meter's probes at the big tab and ground should show 2.5V, pin 3 (right) is the input pin. pin1 (left)
            • Dang
              • Aug 2013
              • 440
              Been researching this one a little more and found that another Voltage regulator is acting the same, it's a FAN1587AD33X, a 3A low dropout voltage regulator, yet again if I spray cold spray over it the horizontal lines go temporarily only to appear again after a few seconds, I've also noticed that if I play a standard DVD signal through the phono connectors on the side the lines are very much subdued compared to an HDMI signal, indeed if the said DVD player is allowed to fall back to it's start up screen the lines are there in abundance??? I can only think it's an amperage issue as both regulators output the voltages at their stated values whether warm or cold, indeed it could be something else that I'm not aware of but I just don't know, I would have to suspect the voltage regulators otherwise why would they react as they do to the cold spray, if any one can help any further I'd be very grateful, thanks again, Andy.
              Both Voltage Regulators are in very close proximity to each other, possibly on the same circuit.
                It can possibly be the filter caps at the input and the output of the regulator, the regulator may be oscillating due to bad caps.
                This is one way to look for bad filter caps if you do no have scope, but have to have good meter.
                https://www.badcaps.net/forum/showthread.php?t=31410
                • Dang
                  • Aug 2013
                  • 440
                  I had a suspicion about the caps but I'm no expert so thank you for the pointer, I shall probably just try and trace back to the voltage regulator's origin of power and just change them all out along that path as I have no setting to test them with, I can get a replacement board for £25 so for the purposes of experimentation I can go with that idea, thanks again, Andy.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • Stanley1843
                    Screen Display Vertical Multicolor Lines
                    by Stanley1843
                    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                    06-29-2024, 11:54 AM
                  • jeyoung12
                    Samsung QN50Q60t lines on screen
                    by jeyoung12
                    Hi all
                    I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                    My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                    This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                    It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                    So....i don't know what end of the C ribbon to work with...
                    02-26-2024, 10:38 AM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • Rubenlily
                    Samsung QE50Q67TAU - horizontal lines
                    by Rubenlily
                    First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                    I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                    I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                    I'm no expert but I've done the tape...
                    08-16-2023, 01:12 PM
