samsung ln46a650
  • splitcrete
    • Dec 2012
    • 387
    • usa
    samsung ln46a650
    Hi everyone
    I need some help with this one . This tv will run for 1/2 hour and inductor l-102 gets so hot it turns the tv off,but as soon as it cools down it will start up by itself with a fuzzy picture.
    I checked the caps and someone changed some of them.
    There are two caps on the power board that don't match the drawing for the power board.
    cm-872 & cm-873 the print says they should be 25-v 470 uf but the caps on the board are cm-872 & cm-873-25-v 1500 uf would that make the inductor hot enough to turn the tv off ? I will check voltage as soon as I know what caps belong on the power board.
    Re: samsung ln46a650
    Did they use general purpose capacitors?
    These inductors are on the power board?
    Check PSU output voltage as the TV runs: see if it starts falling.
    • lanada
      • Oct 2013
      • 50
      • Malta
      try to use a hair dry to locate the fault??
      • inadim
        • Oct 2013
        • 7
        • uruguay
        The inductor gets hot by de ripple,check it.
        • tibimakai
          • Jan 2012
          • 3680
          I have the same TV with a similar issue. Yours turns off completely or just the image? Mine only the image and the audio still works.
          Mine runs for many hours and then the screen goes black. Lately though it didn't do it, since I have changed the power supply board, from another Samsung TV.
          • splitcrete
            • Dec 2012
            • 387
            • usa
            Here are some pics of the caps., and hot inductor.
            The power outputs are on next pic.
            • splitcrete
              • Dec 2012
              • 387
              • usa
              It turns off, and chimes and turns on , and chimes. When it starts itself back up the picture is fuzzy.
              • splitcrete
                • Dec 2012
                • 387
                • usa
                All the caps are factory except the two circled they are Nichicon H0828
                The inductor in question is on the main board, as circled in red.
                  HM, HN, PW... other series?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I would replace them all. Maybe one of those small ones, is the startup capacitor and it's bad.
                    • splitcrete
                      • Dec 2012
                      • 387
                      • usa
                      What do you mean other series?
                      • splitcrete
                        • Dec 2012
                        • 387
                        • usa
                        I bought new caps at my local electronics shop.Enough to do the whole board.
                        What about the two caps that don't mach the drawing.
                        CM-872 & cm-873 print says 25-v 470-uf for both.
                        Someone a Wise Person I guess soldered in 25-v 1500-uf
                        When I re cap the board should I change them two caps per the print.
                          Use the values as designed in not as soldered in
                          • splitcrete
                            • Dec 2012
                            • 387
                            • usa
                            Thank you Tom66 I was just getting ready to start putting them in.
                            Those 1500uf caps Would they make the inductor on the main board very hot.
                            Are the caps I bought OK for this board? Were the value coming out of CN-801 to specs?
                            I hope this solves the problem as this is a big deal for this model.
                            • splitcrete
                              • Dec 2012
                              • 387
                              • usa
                              I recapped the whole board even the caps that checked out ok.
                              I changed the caps with 1500uf-25-v to specs 470uf-25-v
                              Now the inductor is running ay 125-c and not 175-185-c shut off point.The picture is beautiful now what a difference.
                              The guy I bought this tv from had a Samsung class action law suit Cap change from a Samsung authorized repair shop ,and they put in the wrong caps.
                              Thank You Tom66 you are to smart for this planet.,and where do I send the 30 rack of beer (gift cer. of your choice) tomorrow I'm WORKING ON A KDL 40W4100 SONY tab bond problem. I think.
                              • splitcrete
                                • Dec 2012
                                • 387
                                • usa
                                I just did a factory reset and holy cow what a picture.Thanks again for all the info you guys are teaching me a lot of new and useful stuff.
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • ohren
                                  by ohren
                                  09-08-2023, 05:24 PM
                                • C152Heavy
                                  by C152Heavy
                                  Summary for TL-DR readers:
                                  • VCC pin (18) of PFC...
                                  01-11-2023, 02:53 PM
                                  09-07-2024, 05:50 AM
