Philips 42PFL5603D/27 with bad backlight inverter
  • curt2199
    • Oct 2013
    • 54
    I picked up this TV for $50 and the picture quality is decent. The people I bought it from said it would shut off after 5-10 mins. The first night I brought it home, I stuck it on my UPS battery backup with my Panny Plasma and watched Family Guy episodes for 2 hours and it never shut off. After moving it to it's final destination (bedroom) it would shut off much closer to the 5-10 min mark so I started some investigation and found that it the tv is not shutting off, the screen is going black (still playing sound as well) and I can still see the menu/image on it with a flashlight.
    So it appears the backlight inverter(s) is bad. It is now to the point where the time that it stays on is random (sometimes depending on if it is left completely unplugged or if a fan is pointed at the PSU with the back plastic off) and it tends to come on and then flicker and go out.
    My next question is, I've had some experience with electrical parts and soldering having taken some electrical engineering classes while back in college and worked on things here and there. Is this something that I could test and replace parts? I discovered that the inverter is actually built into the power supply.
    I'm attaching a picture of the power supply/inverter used on this TV. (Picture is of the part from an ebay listing).
  • mmartell
    • Oct 2013
    • 3189
    Re: Philips 42PFL5603D/27 with bad backlight inverter
    Use a hair dryer in the suspect area to try to pinpoint failing component(s).
    • notallbad
      • Oct 2012
      • 1190
      You might want to check reverse side for dry/bad solder joints.
      • chestercc
        Philips TV Backlight Repair
        by chestercc
        So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
        My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
        The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
        11-18-2022, 01:15 PM
      • ohren
        Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
        by ohren
        I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
        The setup is basically:
        Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
        Transistor is switching the 3.5 V supply on the power board....
        12-05-2024, 11:10 AM
      • Patrick501
        Philips 55PUS6704 no picture, backlight ok
        by Patrick501
        I'd like to repair a Philips 55PUS6704.
        It turns on and you can see the backlight, hear the sound but no picture.
        When I disconnect one of the T-con cables, half of the screen turns white.
        right cable disconnected= right side white
        left cable disconnected= left side white
        When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
        There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
        Also you can notice one single...
        11-12-2025, 08:46 AM
      • ovrax
        Philips 55PUS6804/12 turn on & off (probably backlight issue)
        by ovrax
        First of all, please excuse me as I'm quite new to this field.
        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
        The Ambilight works perfectly and stays on.
        No sounds.
        Thanks in advance.
        08-25-2024, 04:33 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
