LG 37LF65 backlight goes off
  • Chron-O-John
    • May 2013
    • 15
    • Austria
    I have a problem with my TV and I am hoping you can help me.
    I've got it from someone else and don't how anything about the process of the problem (if it got worse over time or something else)
    The backlight on my LG 37LF65 is not working. When i turn on the TV the backligt is lit for about half a second and then it goes dark. The panel itself is working. If the TV is cold (like outside cold ~ 15° Celsius / 60° Farenheit) it is working fine. I left it running for about 15 minutes.
    If the TV is in a warm enviroment it is not working. This is happening when it's turned on:
    http://youtu.be/fkQuIPwiJqs
    (Don't mind the cat )
    When the light is on I can hear a silent buzzing/humming sound.
    I've checked all the Electrolytic Radial Caps on the Power board and on the Inverter boards using an ESR-Meter. All of them seem ok.
    There's one 1uF cap on the powerboard which has ~5ohms ESR (I think it is C123) is that OK or too high?
    All the voltage readings seem to be OK (at least with CCFLs off)
    I measured the 24V going to the inverter boards (on the top) and the other connectors on the side.
    The 19V outlet is only 18.5, is this enough?
    Next thing I'll measure will be the MOSFETs (but I have to desolder them, right?)
    Oh yea and i have the following Equipment:
    Fluke 77II multimeter
    Capacitor meter (masuring the capacity)
    ESR meter
    Soldering stuff
    I think i could borrow an oscillator from my parents, if necessary, but I have no clue about how to operate it
    Re: LG 37LF65 backlight goes off
    18.5V is fine for 19V... something like 16 or 17V would be bad. Is 24V good even when set fails to work?
    On this board (https://www.badcaps.net/forum/attach...8&d=1381253497), there is ON/OFF and DIM on connector. Check ON/OFF signal when TV works and when it fails.
    Also, check ERROR OUT, again when failed and when working. If it changes state when the set fails, there is a problem.
    • Chron-O-John
      • May 2013
      • 15
      • Austria
      Hmm... where is dimm?
      Here are the readings when its not working:
      ON/OFF: 4V
      VBR: 3.3V
      VIN: 24,5V
      Error Out: 0,317V
      I'll update this post as soon as it is cold enogh for the TV to work.
        DIM = VBR on this panel. But from your measurements looks like bad inverter or tubes as everything else appears OK.
        What you can try is getting a hairdryer (or hot air gun) and heating up one inverter or the other, and see if it fails when you heat one board or the other.
        • Chron-O-John
          • May 2013
          • 15
          • Austria
          Hmm... I left the Tv in a room, window open. Didn't work. I guess it is too warm nowdays.
          Any other advice for now?
            Can you get hold of freeze spray, or canned air? Reversed canned air gives freeze spray.
            • Chron-O-John
              • May 2013
              • 15
              • Austria
              Sorry for not answering for such a long time.
              I haven't had much time last months.
              So I've bought some freeze-Spray. Cooling down the Left Inverter board makes it run again.
              What should i look for next?
              Thanks any Merry Christmas!
                Which is the left inverter?
                • selldoor
                  Slow Learner
                  • 7870
                  Fourth picture post 1
                  Chron-o John
                  Can you narrow down the area you are cooling.
                  Perhaps try reflowing the joints on the inverter transformer
                  • Chron-O-John
                    • May 2013
                    • 15
                    • Austria
                    After leaving the unit alone for some time, i tried to narrow down the area with cold spray.
                    It didnt work. Now cooling down the right board (see post one for pic) seems to do the trick.
                    I am pretty sure that i didn't cool down the right board during the first try. I'll investigate further and write as soon as i know more.
                    I'll also try reflowing as soon as i identified the faulty board.
                    UPDATE!
                    Ok, update guys. It doesn't seem to be any of the Inverter boards, I think I followed the wrong track all the time.
                    The reason it worked after cooling down one of the bords, is simply the fact that I turned if off and on again several times.
                    Plugging out the Power cable and leaving the TV alone for a while sort of "resets" it.
                    When I plug it in again I have to try about 30 times then is comes on.
                    If i continue turning it off and on i'll see the following:
                    https://www.youtube.com/watch?v=21gb...ature=youtu.be
                    (sorry for the bad quality next time I'll use my mobile phone which has a much better video-quality)
                    Hope you can help me!
                    UPDATE2:
                    Ok, now I am completely confused wether its the Inverter board or not.
                    I gave it another try, turned it off an on for about 30 times - didn't work.
                    Cooled the right board, worked after the 5th try or so. 3rd and 4th try the picture was visible for about 3 seconds. 5th try it stayed visible.
                    Thanks!
                    • canadaboy25
                      LG Flatron 24EN33TA No Backlight When Cold
                      by canadaboy25
                      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                      03-07-2023, 12:23 AM
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
                    • DanPoka
                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                      by DanPoka
                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                      02-15-2025, 05:05 AM
                    • Comp_Pro
                      No Backlight Macbook A1990 820-01041
                      by Comp_Pro
                      Hello all,
                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                      Tests performed:
                      There is no backlight even with a good screen.
                      Backlight IC is receiving the correct support voltages.
                      Fuse F8400 ok
                      Current sense resistor R8400 ok
                      Backlight IC is receiving 3.3V on enable pin.
                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                      Backlight IC receiving 5V from PP5V_G3S
                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                      05-06-2024, 10:23 PM
                    • cheebster
                      iPad Pro 12.9 5th Gen Backlight Issue
                      by cheebster
                      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                      Anyone...
                      05-20-2025, 09:17 AM
