Sharp Aquos LC-60LE810UN troubleshooting
+ More Options
Posts
  • micahg
    • Mar 2014
    • 16
    Re: Sharp Aquos LC-60LE810UN troubleshooting
    Hey Fwrothy!
    Thanks so much for the reply. Didn't sound preachy at all. Since I was a new member I couldn't start a new thread, but had totally thought about it. Definitely understand the Christmas light analogy.
    It was still the one fast one slow error code.
    • micahg
      • Mar 2014
      • 16
      Moved my issue to it's own thread...
      https://www.badcaps.net/forum/showthread.php?t=36014
      • Fwrothy
        • Feb 2014
        • 178
        I think all you had to do was introduce yourself to forum in order to post new thread.
        I'm sure someone will have better answers and trouble shoot procedures soon. Best of luck with your repair
        • electronicsurplus
          • Jun 2012
          • 210
          I have the same set BUT, the buttons are sensor touch LC-60LE810UN So, there is no real way to know if the button is pressed or not or, is it still the same?
          Anthony
          This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
          Help keep these from the landfills
          • electronicsurplus
            • Jun 2012
            • 210
            Originally posted by freakaftr8
            Just curious. So instead of doing it that way I found that holding down vol+ ch dn and plugging it in bypasses the error on 2 different sharp tvs I have. An 80" and a 32" .that didnt work for your set? Read up in my post here ti see what I have done there still working great this way.
            https://www.badcaps.net/forum/showth...ht=lc-80le632u
            id like to know if it works cause I have a 60le810un sitting at home gutted. All I have is a panel and casing. I am thinking of ordering all the boards for it.
            I have all the boards for this set took completely apart and lost all the screws So, I am selling the entire lot of boards for $200. Had the 1-1 blink code found the burnt Led strip replaced it now I cannot for the life of me find the panel screws, Cover screws, etc.
            • carlp
              • Apr 2015
              • usa
              #66
              Hi, my Sharp LC-60LE810UN TV bit the dust Friday night. Lost pic & sound with inverted V flashing 1 fast & 1 long. I came across your web site, followed some advice and by holding down -vol., +channel, & pwr buttons simultaneously now have sound, very dark picture, and steady lite inverted V. I can turn the TV on & off with the remote, however, the picture cannot be seen. It's there, however, there is not enough illumination to make it visible. Reading different comments regarding this particular TV makes me think that a LED may have gone bad affecting a whole strip. Does that sound plausible? My electronics background is limited to having worked in the telco field in construction. I enjoy the forums and have become a member. TIA, Carl.
              • freakaftr8
                • Oct 2012
                • 3743
                Yes Carl. You most likely have a burned out led in one of the strips. Check the first led in the upper right hand corner for some reason this one likes to go bad first. Use a dmm in diode check mode to get each led to lo ight up.
                • Nick's Tvs
                  • Jan 2014
                  • 621
                  I have an LC-60LE810UN.
                  Original problem 2 slow 5 fast. I send the main board to a repair service. I get the board back and instal it into the tv. I get 1 slow 1 fast. I have the tv on and blinking while I do the Volume down channel up and power button force turn on code. Tv stops blinking and with a flash light I can tell the panel is on and the menu audio video works fine, but the backlight is not there. I open up the panel and find the upper right LED strip has 1 bad LED and its the opposite of everyone else, somehow the very last LED got affected. I tested the other LEDs one by one with a 1.5 volt battery and wires taped to each side. That was a fun 5 hours of my life. Anyway all others tested ok. I bought a new LED strip since I was not comfortable replacing the LED itself. I still got the 1 slow one fast. I did the force turn on and this time I am getting the LED strips to turn on for 3 to 4 seconds then shut off before the panel actually displays picture. I have tried all the codes to bring the service mode back up, but I can't manage to do so. I have tried holding down volume down input and power button while plugging in, I have tried holding the power button down for 5 seconds right after power up as someone else suggested earlier it would disrupt the flashing and then you could follow up with a different code, but I never got it to disrupt the flash in the first place. I have tried plugging it in while holding volume up and channel down alone, also nothing.
                  The only thing I could do was volume down channel up and power button but that only turns the tv on. It doesn't bring me to the service menu and the LED's still don't stay on for more than 3 or 4 seconds.
                  As I kept reading, it looks like my power supply might be bad as well. How can I test the power board? I really don't want to throw in $250 for the Power supply unless its an absolute certainty mine is bad. I have already spent enough money on this set.
                  I have tested all diodes transistors, resistors, and fuses. All seemed ok.
                  Is it the actual inverter that is bad? How can I check an inverter? Can I buy the inverter alone? Would that fix the problem?
                  Can anyone point me in the correct direction with this one?
                  Thank you
                  • mille415
                    • Jul 2015
                    • US
                    #69
                    I have a sharp LC-60LE810UN and i am getting the one short one long. Took the tv apart and tested the 316 bulbs and found the bad one on the one of the strips that has 30. I have been unsuccessful of finding an affordable replacement strip. Does anyone know where to get one or how to cheaply fix the existing strip(not sure if i can replace the bulb with a resistor or another bulb).
                    • electronicsurplus
                      • Jun 2012
                      • 210
                      How is it possible to use the Vol - and Input or Vol - Ch Dn functions when using touch sensor buttons since there are NO buttons to depress ???
                      • larry708
                        • Jan 2017
                        • 15
                        • us
                        #71
                        Anthony
                        did u ever figgure out your issue. i got the same issue and same tv
                        • jhaag812
                          • Jan 2017
                          I am dealing with the LC-60LE64OU. I have replaced main board as well as the tcon board. Still have the same one short one long blink. I ve tried all of the codes multiple times. Im about to take a baseball bat to it. Please send me some helpful info on what I'm missing or send your favorite brand of bat.
                          Thanks in advance
                          • sefoster
                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                            by sefoster
                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                            11-20-2022, 09:29 AM
                          • jonah1024
                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                            by jonah1024
                            Hello!
                            I'm a few days old into this TV screens repair universe so please bear with me.
                            Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                            - I did a factory reset as well...
                            07-16-2024, 04:23 AM
                          • klassic
                            Sharp Aquos LC-60LE635E three blinks
                            by klassic
                            Hi community,
                            I will describe my problem with a TV in those short following terms to be the most precise :
                            What i have :
                            power board DPS-162KP-1
                            main logic board QPWBXF733WJN2
                            symptoms :
                            white led light logo at startup,
                            after 2 minutes, blinking 3 times a row, repeating
                            no backlight (and apparently no picture, checked panel with flashlight)
                            no startup sound
                            powerboard investigations :
                            1-2 PNL : 0v
                            3-4 GND
                            5-6-7-8 UR : 13.15v
                            9-10-11-12...
                            10-24-2023, 01:39 PM
                          • Kingfreddie
                            LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                            by Kingfreddie
                            Ok.. this is the story:
                            Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                            This is kinda how it looked, just that mine were at the bottom of the screen:
                            09-11-2021, 01:57 AM
                          • foxyUK
                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                            by foxyUK
                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                            10-22-2024, 10:27 AM
