LG 47LC7DF-UK Sound but no Video
  • Mongor62
    • Sep 2013
    • 83
    • California
    Just like the title says i have sound but not video
    What i have done so far (besides invading someone's thread) is replace the 2 large caps(450v 150uf) and the fuse(250v 5A) near it that was blown and i still have the same problem and the TV works exactly the same as it did before i did anything and with or without that fuse installed, which is now blown just like the original.
    I own a Fluke 87 and am a novice at using it. just would like to know where to attack from here but my lack of experience is holding me back.
    Power supply model = P/N : 2300KEG021A-F
    Main board model = LA75A EAX38059704 (0) 071129 H.Y.H.
    Pics are of my TV and i include the plug because my TV is a UK version not a UB version and just trying to find out if it is the wrong region or i have the wrong cord. The version matters because i cannot find any sort of Service manual besides the UB version which is different from mine. The UB version of my TV have separate inverter board and the way i understand it mine has that integrated into the power supply. Also included picture of the cover to the power supply to show the plastic that was distorted due to heat.
    Much of this has been posted in another person thread and i am sorry about doing that.
    Any help is greatly appreciated.
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: LG 47LC7DF-UK Sound but no Video
    You say you have no picture, but does the screen have a glow? Ie. Is the backlight on but the screen is black? If that's the case you may have either a tcon problem or a bad panel.
    If there is no glow or backlight, try the flashlight test. Shine a bright flashlight while playing a movie and see if you can see a faint image on the screen. If this is the case you probably have a problem with the psu/inverter circuit.
    • Mongor62
      • Sep 2013
      • 83
      • California
      When last i had it on to the best of my recollection it had nothing at all.
      As stated in original post it performs the same with and without the fuse and i don't have another fuse (replacement blew) to use but could this test be done without the fuse either way?
        " i did anything and with or without that fuse installed, which is now blown just like the original." So the fuse is still blowing?
        OK, just read the post 3 just second before I post. So you do have badly shorted circuit that blow 5A fuse. We will need real good closed up pictures of this power supply-inverter board combo to see what circuit this fuse is feeding. Good top and bottom side of the board, then small section of both top and bottom side so I can clearly see the traces and component to be able to trace out the circuits.
        Just remember that we do not have the board in front of us to look, just the pictures.
        • Mongor62
          • Sep 2013
          • 83
          • California
          What i mean is the things i replaced were the 2 caps and the fuse which was not working and after i put it back together with the new fuse it blew again. I took the fuse out and still does the exact same thing no video but sound. I do not have another fuse to use atm and before i made another order from digi i was looking for some more advice because ordering 10 fuses wouldn't help me right now, at least i don't think
            We will need the pictures to find out the function of that fuse. I would not keep putting in the new fuse since you can cause more damages until we find out why the fuse blew.
              http://assets.shopjimmy.com/media/ca...36781302_1.jpg
              OK, I see the fuse now, that is probably the fuse for the inverter circuits, so more likely that the inverter circuit has shorted out power MOSFETs (they are mounted on the longest heat sink close to inverter transfromers)
              • Mongor62
                • Sep 2013
                • 83
                • California
                I already have some pics of the board and you even linked me differences the UB and UK versions of that same power supply so i don't think you are asking for that so i took some more pics of the fuse itself.
                As i am a novice i did the best i could to research what fuse to buy to replace this i bought the one linked below.
                http://www.digikey.com/product-searc...&formaction=on
                • Mongor62
                  • Sep 2013
                  • 83
                  • California
                  As i was putting together my last post with pictures you are talking about the very thing i was reading about but i have a lack of comprehension but know the pieces you speak of that are screwed in to the aluminum heat sinks.
                  • Mongor62
                    • Sep 2013
                    • 83
                    • California
                    I numbered the items you speak of to help me understand what you are talking about so if you could take a look and tell me a little more
                      6~10 are the components you need to check for very low resistance reading. I cannot tell much more until I can see the bottom side of the board to see how many MOSFETs and how many Diodes for those 6~10 components.
                      Get the numbers as printed on those components also.
                      • Mongor62
                        • Sep 2013
                        • 83
                        • California
                        These are pics of the bottom of the board and i will take some time to make sure i get the numbers written on those items and get back to you
                          Ok, the pictures are kind of blurry. Can you tell me which one of the components form 6~10 has 3 legs?
                          OK, 5 and 10 are the MOSFETS that we need to test for low resistance reading.
                          if you at it facing you:
                          Left pin is 1
                          Middle pin is 2
                          Right pin is 3
                          Use the Ohm meter to test:
                          Pin 1 & 2
                          Pin 1 & 3
                          Pin 2 & 3
                          Test both ways (swap the probes around after)
                          • Mongor62
                            • Sep 2013
                            • 83
                            • California
                            6. 2pins 920 SFAF508G
                            7. 2pins K16 R860PF2
                            8. 2pins K16 R860PF2
                            9. 2pins 920 SFAF508G
                            10. 3pins SD20N60 GAY908
                            pins = legs
                            • Mongor62
                              • Sep 2013
                              • 83
                              • California
                              If i am correct the TV needs to be plugged in and everything connected to do this test?
                                No! we are taking resistance reading, not voltage reading. When you report the readings please make sure to tell us if the reading is xxx Ohms, xxx K Ohms, xxx M Ohms.
                                • Mongor62
                                  • Sep 2013
                                  • 83
                                  • California
                                  1. 4pins D15XB 60 B018D ("8" has a dash over it and "D" has a dash below it)
                                  2. 2pins MURF1060 SSG A09182
                                  3. 3pins SD20N60 GBY908
                                  4. 3pins SD20N60 GBY908
                                  5. 3pins cannot find any numbers or letters on this item?
                                  11. 3pins 04N60C3 GAB 918
                                  12. 3pins N 9B FCH10A20 K7A
                                  13. 3pins N 9B FCH10A20 K7A
                                  14. 3pins N 8K FCU20UC30 339
                                  15. 3pins F1 K15 FQPF 27P06
                                  I will be testing the 3pin ones first.
                                  3. meter was showing a M so i figure that means M
                                  Pin 1 & 2 1.256 but climbed slowly from 1.0
                                  Pin 1 & 3 23.68 steady
                                  Pin 2 & 3 335.1 steady
                                  5.
                                  Pin 1 & 2 1.856 steady M
                                  Pin 1 & 3 10.07 steady K
                                  Pin 2 & 3 no reading just says O.L
                                  10.
                                  Pin 1 & 2 13.5 steady NOT K OR M
                                  Pin 1 & 3 13.3 steady NOT K OR M
                                  Pin 2 & 3 .04 steady NOT K OR M
                                  11.
                                  Pin 1 & 2 .425 -.606 and kept rising slowly (this took place over 40 second span) M
                                  Pin 1 & 3 10.09 steady K
                                  Pin 2 & 3 .829 kept rising like 1 &2 M changed to 1.225 slow and i mean slow rising M again changing .9876 M going down
                                  I will do 12 - 15 in a little bit and post this now to keep you from waiting.
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    # 10 looks like the culprit looks like all three pins have been shorted on it, replacing it should fix the problem. You should also test 6-9 for shorts also just in case.
                                      I would replace #5 and #10 at the same time, including the PWM IC (8-pin device next to #5 that drive these two MOSFETS, the resistors/Diode network on the Gate hsould also be checked for damaged.
                                      Take the MOSFETs out and test them out off the board.
                                      • Mongor62
                                        • Sep 2013
                                        • 83
                                        • California
                                        I just wanted to update my readings that i got today just to make sure we are all on the same page.
                                        Pin 1 & 2 1.249 M
                                        Pin 1 & 3 23.67K
                                        Pin 2 & 3 1.288M
                                        Pin 1 & 2 1.247M
                                        Pin 1 & 3 23.67K
                                        Pin 2 & 3 1.287M
                                        5. I still cannot find a P/N
                                        Pin 1 & 2 2.055M
                                        Pin 1 & 3 10.07K
                                        Pin 2 & 3 OL
                                        6-9 are tested with black lead on 1 and red lead on 2; then next reading is with red lead on 1 and black lead on 2.
                                        BL1 RL2 1.992M
                                        RL1 BL2 OL
                                        BL1 RL2 .3 OHM
                                        RL1 BL2 .3OHM
                                        BL1 RL2 1.570M
                                        RL1 BL2 1.933M
                                        BL1 RL2 1.863M
                                        RL1 BL2 1.583M
                                        Pin 1 & 2 13.2 OHM
                                        Pin 1 & 3 13.2 OHM
                                        Pin 2 & 3 .3 OHM
                                        Pin 1 & 2 10.09K
                                        Pin 1 & 3 10.09K
                                        Pin 2 & 3 .3 OHM
                                        I know that its a different section of the board but i got 12 too just in case but 13 and 14 the readings change if i had the negative lead on pin 1 or 2 like the polarity mattered.
                                        Pin 1 & 2 194.1 OHM
                                        Pin 1 & 3 .3 OHM
                                        Pin 2 & 3 193.7 OHM
                                        What does this mean "the resistors/Diode network on the Gate hsould also be checked for damaged."?
                                        I posted a pic of the 8 pin item just checking to see if it the same as what you are talking about. Also i think i have a grasp on ordering CAPS but ordering other things like the MOSFETs (i don't even know if i am using that right) & PWM IC or even Fuses i am very shaky at so a little help here would go a long way.
                                        Having some trouble understanding your schematic.
                                        • soeren
                                          A2442 - No sound over internal speakers and no video playback
                                          by soeren
                                          I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                                          All happened after the battery ran out of power overall several days when I was on vacation.
                                          I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                                          07-26-2024, 01:24 AM
                                        • JRade
                                          Audio video receiver KENWood KR-V990D,no sound
                                          by JRade
                                          When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                                          The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                                          I replaced the capacitor C303/0.047F, nothing changes.
                                          I'm asking for help, what should I do next?
                                          Thanks in advance!...
                                          08-05-2025, 10:23 PM
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
