Vizio E3D470VX Logo Stuck on Screen
  • barryra
    • Aug 2013
    • 107
    I have a few questions in my Vizio E3D470VX... I turn on.. & the V logo shows & I cannot do anything else. If I press buttons.. Nothing just the V logo.
    I am hoping it's not the main board but rather some type if update. What do you think it may be? Thank you
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Vizio E3D470VX Logo Stuck on Screen
    Sounds like corrupted eeprom.....on the main board, but you should check the voltage regulators for good measure. See this thread for the low down
    Liberating magic smoke one part at a time
    • barryra
      • Aug 2013
      • 107
      Caleb.. Thank you for the response. Wouldn't the board need to be replaced if it was a bad eeprom? Since they are programmed to a specific tv?
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
      • conghuyms
        MacBook Air A2179 stuck logo , pls help me !
        by conghuyms
        Hey everyone,
        I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
        When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
        I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
        11-05-2025, 08:30 AM
      • paulxxxx
        Vizio E701i-A3 stuck at logo, need service manual
        by paulxxxx
        The TV stuck at logo and cannot be turned off unless the cord is unplugged.
        I was given two main boards and exactly the the same thing happens to both of them.
        I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
        There are no signs of damage on any of the 3 boards.
        Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
        Thanks!
        09-08-2023, 01:11 PM
      • abajor
        A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
        by abajor
        Having this very weird issue.
        The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
        I swapped with a working screen from an A2141 waiting for parts.
        The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
        The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
        04-27-2024, 01:37 PM
