re phillips 42 plasma
  • himinshed
    • Aug 2013
    • 20
    • australia
    phillips 42pf9766/79
    The TV is a Phillips 42pf9766/79 Chassis FTP 2.2a aa
    HELLO ALL About a month ago we heard the occasional sharp crack comming from the set i dont realy know if it was comming from the set or though the speakers then one night the sound went off shortly followed by the picture the set went into protection mode .
    Now when i press the start switch i get a blue L.E.D on the front for about 3 seconds then the red led flashes and the set goes into protection mode and shuts down .Onthe PSU THE 3 GREEN leds go on the top2 go off after a short time leaving the bottom one on .The red fault LED on the left hand side of the PSU does not come on . I took the PSU board out of the set and inspected all the Caps ,could not see any distortion or leakage but the transformer with a board id V3T 8005 with a tag KE 0447A had a slight discoloration like it could have been hot at sometime The voltage on the silk screen =VS 175 Volts my board is 9.1
    Vset= 173 Volts my board is 0Volts Vscan=60 Volts my board is 0Volts VCCS =18Volts my board is 132 volts.. The other voltages are as per silk screen .I disconnected xand y main boards and found no change to the voltage at the test pionts Any help with this fault would be greatly appreciated As there is no other visable signs other than a slight browing of the transformer (Could this be the problem) Cheers Shaynhttps://www.badcaps.net/forum/images/smilies/cheers.gif
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: re phillips 42 plasma
    If youve got 132 volts where there is only supposed to be 18v you may be better off getting a new board rather than trying to troubleshoot that one. That high of a voltage will surely have damaged multiple components.
    Liberating magic smoke one part at a time
    • MisterAIL
      PS5 digital / No Power / No Beep / Good power supply
      by MisterAIL
      Brought a non functionnal PS5. Apparently only a bad PSU...
      No beep, nothing.
      After some tests i found this :
      - PSU is fine (12 volts stable)
      - 12 volts line is shorted
      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
      - By the way, nothing change. No signal, no power, no beep.
      Mesuring all rails with my workbench psu (12 volts input)
      - 0.00 amp drawing
      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
      03-12-2024, 03:24 PM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
    • BTubbs200
      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
      by BTubbs200
      Dell Latitude 5420 P137G
      Board: LA-K491P REV A01
      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
      Board seems to have no shorts, all power rails are fine and show high resistance.
      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
      01-24-2025, 08:15 PM
    • Uranium-235
      Phillips 50PF7321D/37 Plasma slow reboot
      by Uranium-235
      Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
      12-27-2021, 09:14 PM
      MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
      I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
      I open it up to find non brands name capacitors in it
      I am not sure how this switching power supply is set up
      Could someone please explain how this power supply works
      Here is the capacitor ESR results
      (1) 47uf@50 volts 0.46
      (2) 47uf@50 volts 0.45
      New 47uf@50 volts 0.35
      (1) 100uf@25 volts 0.34
      (2) 100uf@25 volts 0.35
      New 120uf@50 volts 0.08
      (1) 220@25 volts 0.13...
      10-21-2018, 10:02 AM
