42762hdf
  • sordids999
    • May 2013
    • 2157
    42762hdf
    hi guys got a Acoustic Solutions stuck in standby anyone had this problem before ?
    thanks
  • sordids999
    • May 2013
    • 2157
    Re: 42762hdf
    ok update tv wont turn on so swopped another power unit i had but still the same no backlight or picture so disconnected the invertors one by one and the backlight tried to light up running off one invertor
    so would u guys say its the invertors thats the problem ?
    i know @tom has worked on this kind of tv
      Re: 42762hdf
      I have not worked on this TV. I have worked on some Vestels, but not this model or chassis.
      Probably not the inverter... how sure are you that your spare PSU is good? 90% of failures are due to poly caps on PSU board.
      • sordids999
        • May 2013
        • 2157
        Re: 42762hdf
        opps sorry tom my bad it was a different model i watched on your youtube videos
        the power supply is 17pw16-2 i have a spare i removed from a working tv but still the same problem
          Re: 42762hdf
          Check the 24V supply to the inverters when both and when just one are connected.
          • winchesterr
            MSI GF66-11UE MS-1581 BOARDVIEW
            by winchesterr
            Hi guys, I have a problem with my laptop which is MSI GF66-11UE. 3-4 days ago I wanted to change thermal paste,unfortunately one of screw was become stripped and I forced a little bit that screw.Anyways when I finished the change of thermal paste and picked up the laptop at last I realized that I didn't put the edp connector inside but the problem is I put this while the battery was still connected the motherboard.That caused a few sparks.
            Fortunately, the laptop booted up afterward. However, it was running using the CPU's integrated graphics, and it didn't detect the dedicated...
            04-06-2025, 11:07 PM
          • rustinjust
            Technika lcd 32 - 207, question about board compatibility
            by rustinjust
            My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
            Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
            Link to part here https://www.ebay.co.uk/itm/222990805243
            This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue...
            10-06-2023, 08:53 AM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • zmeutul
            hi guys i need bios for 6-77-NP50PNJY-D02B-3C
            by zmeutul
            hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
            09-26-2024, 01:55 PM
          • Norag33
            HP 15-da0073wm display issue
            by Norag33
            Hey guys i need your help to fix this problem with this HP 15-da0073wm i7-8550U, this laptop originally has a 40 pin display connector for the Cell Touch eDP display and since i couldn’t acquire that display i decided to adapt the 40 pin connector to 30 pins discarding the touch related pins since the first 30 pins are the same as non-touch eDP displays, the problem is that it worked but not as i expected, you can see the problem in the pictures, i already tried to isolate the display cable from external interference or i think so, i tried with other displays but no video just black screen,...
            07-05-2025, 03:40 PM
