42762hdf
  • sordids999
    • May 2013
    • 2161
    42762hdf
    hi guys got a Acoustic Solutions stuck in standby anyone had this problem before ?
    thanks
  • sordids999
    • May 2013
    • 2161
    Re: 42762hdf
    ok update tv wont turn on so swopped another power unit i had but still the same no backlight or picture so disconnected the invertors one by one and the backlight tried to light up running off one invertor
    so would u guys say its the invertors thats the problem ?
    i know @tom has worked on this kind of tv
      Re: 42762hdf
      I have not worked on this TV. I have worked on some Vestels, but not this model or chassis.
      Probably not the inverter... how sure are you that your spare PSU is good? 90% of failures are due to poly caps on PSU board.
      • sordids999
        • May 2013
        • 2161
        Re: 42762hdf
        opps sorry tom my bad it was a different model i watched on your youtube videos
        the power supply is 17pw16-2 i have a spare i removed from a working tv but still the same problem
          Re: 42762hdf
          Check the 24V supply to the inverters when both and when just one are connected.
          • winchesterr
            MSI GF66-11UE MS-1581 BOARDVIEW
            by winchesterr
            Hi guys, I have a problem with my laptop which is MSI GF66-11UE. 3-4 days ago I wanted to change thermal paste,unfortunately one of screw was become stripped and I forced a little bit that screw.Anyways when I finished the change of thermal paste and picked up the laptop at last I realized that I didn't put the edp connector inside but the problem is I put this while the battery was still connected the motherboard.That caused a few sparks.
            Fortunately, the laptop booted up afterward. However, it was running using the CPU's integrated graphics, and it didn't detect the dedicated...
            04-06-2025, 11:07 PM
          • rustinjust
            Technika lcd 32 - 207, question about board compatibility
            by rustinjust
            My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
            Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
            Link to part here https://www.ebay.co.uk/itm/222990805243
            This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue...
            10-06-2023, 08:53 AM
          • GardevoirForEver
            Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
            by GardevoirForEver
            I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
            Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
            The motherboard of my ASUS...
            11-15-2025, 04:30 PM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • zmeutul
            hi guys i need bios for 6-77-NP50PNJY-D02B-3C
            by zmeutul
            hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
            09-26-2024, 01:55 PM
