LG 42LG3000 LCD TV Fault Finding.
  • DejaVu
    • Sep 2013
    • 15
    Hi Badcaps, great forum, incredibly helpful members and hopefully kind enough to lend a hand with this TV I'm having problems with.
    Searched the forum and found similar issues with no definitive answer, so had to create a new thread.
    I am new and only repaired a couple of sets in the past, so please go easy and have some patience with me. Thanks.
    Took my 42LG3000 apart in the lounge and trying to suss out the faulty board.
    Here is a video of the symptoms...
    http://www.youtube.com/watch?v=LCWH8EON5j8
    It can't really be seen in the video, but after the backlight flashes, the LED light on the right is a steady faint blue, so power still remains. I'm not sure of what the LED colours are meant to be when operational as I've only just acquired the set 'as is'.
    At first I suspected the Invertor boards. Disconnected them and tried the TV. LED remains faint blue.
    Next, disconnected TCon board. Same thing. LED remains faint blue.
    Only boards left are the PSU and the mainboard. The mainboard controls the LED so from here I'm a little stumped. All Capacitors appear in good shape, although I do not know for certain.
    Anyone willing to lend some experience on how to test the boards or advise what I'm doing wrong or even to just take the mickey because I've done it all completely wrong?
    As recommended, here are the images of the inside of the set and the boards. Not shot the TConn Board yet, still covered over with the plate.
    Photo's on Dropbox -
    https://www.dropbox.com/sh/1wope3wgily61mh/JIPb_JyU8b
    Tried embedding them, but didn't work.
    More available on request.
    Opinions on another forum point towards the PSU, but I'm not sure as it powers on and stays on. So thought I'd 'Ask the Experts'.
    Will post all findings and results in here to help any other members in the future needing assistance with this Telebox.
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: LG 42LG3000 LCD TV Fault Finding.
    First thing I would check is the resistance on each coil of the backlight transformers. See if they are the same. Use a mutimeter on Ohms, Next check would be the output voltages on the power supply- most of the time the values are written on the board next to the connectors.
    Liberating magic smoke one part at a time
    • DejaVu
      • Sep 2013
      • 15
      Just used a multimeter on the PSU outputs of 5v and 12v.
      5v reports 5.13v.
      12v reports nothing at all.
      Seems the PSU is at fault then? Is it worth fault finding and replacing components or better to just replace the board?
        Check the PS ON signal from main board is turning on first, if it does not send that signal 12V will not come up.
        • DejaVu
          • Sep 2013
          • 15
          Forgive my n00bness tom66, but how might I go about doing that with this board? I'm guessing you mean this one?
          https://www.dropbox.com/sh/1wope3wgi...2017.13.15.jpg
          From what I understand, what you're saying is, the mainboard is checked using 5v - perhaps for Standby, if everything checks out and the power button is pressed, the mainboard tells the PSU to fire up the 12v to power the backlight. If the mainboard is failing to tell the PSU (or the PSU is failing to provide 12v) to fire up, it wouldn't be there... hence why the screen is going off - although the backlight does fire up, but goes out within a blink of an eye.
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            You are looking for a pin tagged ps on or bl on to test for the signal turning on the power supply. Try having your test probes on the 12v and get it when the back lights flash on. Usually if they come on then extinguish the inverters are at fault, but could be power supply, main or bulbs too. BTW the link is to an empty folder
            • DejaVu
              • Sep 2013
              • 15
              Hunted all round both boards and found this on the PSU. It's about as close as I can find.
              https://www.dropbox.com/s/6vw3ehayll...2019.34.41.jpg
              I'm guessing its the third pin from the left at the top marked ON/OFF. Is this the one that would be activate 12v?
              I'm thinking I'll have to wrap a small wire around it, replace the connector and test it with the multimeter. This is the same connector that powers the Mainboard and looks to be the only one that does.
              • DejaVu
                • Sep 2013
                • 15
                Been checking pins today following this thread https://www.badcaps.net/forum/showthread.php?t=20824 - which has excellent descriptions of what to do and how! Checked the Invertor fuses, both have continuity.
                Then I got to the part of '24v to the Invertor boards' and while everything is connected (and in what would be standby mode) I get nothing, nuda, zip. I've checked the 24v on the actual PSU and doesn't seem to be there either.
                https://www.badcaps.net/forum/showth...937#post241937
                What does this mean?
                Is the TV waiting to be taken out of Standby before it feeds 24v to the Inverter Boards or should that be there already?
                Or is the PSU screwed?
                Still looking for this, but I'm going to try and see if I can get 24v from the Fuse on the Invertor board to the Chassis when the LCD Panel switches on. Is it OK to do this?
                  The 12v/24v power supply section is turn on by the Main board, the signal is typically called PS_ON. That is the pin on the power supply board you need to find out if it is receiving the turn on signal from the main board or not, PS_ON is typically about 2~5vdc. Please read my Basic LCD TV troubleshooting guide.
                  • DejaVu
                    • Sep 2013
                    • 15
                    Great guide and explained a ton!
                    But this is why I'm getting a little lost because PS_ON and BL_ON doesn't seem to exist on this board.
                    I *think* I've got it in this picture and I'm guessing it's the ON/OFF (24v?) pin I should be looking at?
                    Also got something called BRI there too (Somesort of Bridge?)
                    As well as INV_ON... which is quite obvious now I've thought about it! = BL_ON I guess?
                    AND Power_On also lives there too!
                    https://www.dropbox.com/s/6uksajpon0...2016.06.56.jpg
                    Confusion!
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      If you trace the inverter on around and down it goes to the on/off pin, then right next to it is the power on which = ps on. You will want to test both and see if they are receiving a signal from the main board to turn on, as Budm said somewhere between 2-5v. If you are not receiving the signal you can force on the power supply by putting a 1k resistor between the 5v pin and the power on, same thing for the inverter on signal.
                      • truep
                        • Aug 2010
                        • 373
                        The on/off turns the Power supply (12 and 24V) on. the inv on is the same as BL on.
                        • DejaVu
                          • Sep 2013
                          • 15
                          Aha, after turning on (and the backlight flickers and the LED goes a faint Blue)
                          All voltages are as they should be.
                          Invertor boards are receiving 24.2v.
                          12v is pushing out 12.3v
                          5v is pushing out 4.8v
                          Will check what INV_ON is using, but I'm expecting 24v right?
                          -edit
                          Nope. INV_ON is at 4.7v after the backlight flickers.
                          But on 0v before trying to turn it on (Switch at wall and before Remote Power pressed). So I'm guessing that's correct?
                          I'd just like to say, thank you all soooo much for your help with this. Hugely appreciated!
                          This looks to me like it could be the Invertor board's yeah? I've checked the surface mounted fuses and they appear fine.
                            OK, the inverter on can be 2~5VDC, so it looks like you have all the correct voltages but there is problem in the inverter board.
                            I cannot see the pictures in your DROPBOX in the earlier post.
                            Which one of these are the inverter boards in your TV?
                            http://www.shopjimmy.com/catalogsear...?q=LG+42LG3000
                            • DejaVu
                              • Sep 2013
                              • 15
                              I'll take some fresh ones. Not sure what happened to the old ones...
                              Galaxy S3's have a pretty good camera!
                              Master Invertor Board
                              https://www.dropbox.com/s/rra4ivv8xx...2019.18.01.jpg
                              (I've tested F2 and appears OK)
                              Slave Invertor Board
                              https://www.dropbox.com/s/feb1j1emfo...2019.18.17.jpg
                              (I've tested F200 and appears OK)
                              VT71053.50 & VT71053.51
                              • DejaVu
                                • Sep 2013
                                • 15
                                D'you reckon these need replacing or can they been repaired perhaps?
                                If not, can I replace them with VT71053.54 & VT71053.55 as they seem to be more widely available.
                                • Caleb
                                  Smokin IC's
                                  • Feb 2013
                                  • 645
                                  Have you tested those transformers yet? You want to test primary and secondary sides with ohm meter and see if they are the same (pins marked 9 and 12 are secondary) Unless you happen to have a ring tester handy?
                                  • DejaVu
                                    • Sep 2013
                                    • 15
                                    Looking back on the thread I referenced earlier, I got an idea what exactly you meant and have probed them.
                                    This is what I get back measured using the DMM on 20k Ohms.
                                    Master -
                                    https://www.dropbox.com/s/dex5ce1ba91gwwk/Master.jpg
                                    Slave -
                                    https://www.dropbox.com/s/9xkzl4i6x32qj0z/Slave.jpg
                                    Both are the same, so I'm hoping it's right?
                                    Looking at them points close up like that makes them look a right mess!
                                    • DejaVu
                                      • Sep 2013
                                      • 15
                                      Major update.
                                      Unplugged the Slave and left the Master in.
                                      Turned on the TV.
                                      Stays on and can see 'The Fly' for a around 3 seconds.
                                      Left hand side (Slave's side) is dark, then goes off.
                                      Think the faulty board has been located!! Can it be diagnosed!?
                                        Check fuse on it, check for burnt components.
                                        • cheeky2
                                          LG 42LG3000 Strange fault will not go into standby!
                                          by cheeky2
                                          I have this LG 42LG3000 Tv which operates on all inputs without any issues whatsoever. However when you try to turn the Tv off the screen goes blank as it would normally however it then turns itself back on again!
                                          So far I have replaced the main board without any resolution to the problem.
                                          When the inverters master and slave VIT71053.54 VIT71053.55 are disconnected from the power supply then the TV will turn off as it should (obviously without any ccfl output).
                                          I have read through a few posts for this model without anyone having this issue as far as I can tell.
                                          I...
                                          05-04-2021, 06:02 AM
                                          ESR meter came to the rescue again today with a PLC I/O card fault
                                          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                          12-18-2023, 08:17 PM
                                        • mchen96
                                          MSI Optix G241 - Lines
                                          by mchen96
                                          I have an MSI Optix G241 monitor that basically displays gibberish (see below). For context, I am a well-equipped hobbyist that dabbles in electronics and has repaired more than a few things, but I am not a professional nor have I formally studied electronics.
                                          The monitor has two main PCBs. The first one is located under a metal shielding and contains the main power supply, backlight supply, HDMI inputs, and connectors for the power button, menu controls, and power led. The second board is connected to the panel via permanently attached flex cables;...
                                          12-23-2023, 01:03 AM
                                        • cazi1001
                                          Strange fault on Lenovo ThinkPad E14 Gen. 2
                                          by cazi1001
                                          I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                                          The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                                          On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                                          03-24-2024, 04:16 AM
                                        • PanicMechanic
                                          Extech EX330 multimeter current range offset fault
                                          by PanicMechanic
                                          My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                                          The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                                          As you can see from the pics, the offser is the same (just multiplied for other rages):
                                          -4.9 uA
                                          -0.49 mA
                                          -0.49 A
                                          I don't know what exactlly caused the fault.
                                          The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                                          05-11-2021, 11:13 PM
