Pioneer Plasma Model# PDP-5070PU main board bad?
  • philliesfan30m
    • Aug 2013
    • 542
    ok when i got the tv the standby (red light) and power (blue light) were on constantly i haven't dealt with a plasma before so i'm new to them. i read that it goes into "trap mode" when the back panel is off and it is powered on which causes the "trap mode" so the person who had it or someone else had it off with it powered on before disabling the "trap" i also knew they had it off because they didn't replace all the screws and some were installed improperly but anyways. i have the remote and used it to get to "service mode" but it won't show the "initializing page" for me to complete the process. the screen lights up a little then shuts off before i can get to the "initializing page" which is about 10 seconds i tried it several times to no avail. i read that means that the main board is bad. so how can i troubleshoot the main board to find out the problem and to fix it or is it fixable? here are some pics of all the boards i will get better pics if needed. it is an older plasma made in 2006 and the model on the chassis is PDU-PC50X07 it has very little usage on it. thanks in advance for any help given!
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Pioneer Plasma Model# PDP-5070PU main board bad?
    i checked all the voltages going to the y and x drive assembly and to the main video board and the hd digital assembly and they all read the right voltages printed on the board. when i reset the trip mode the red light on the main video board is on but it still won't power the tv on and i don't get any blinking error codes either. any help please?
    • philliesfan30m
      • Aug 2013
      • 542
      but if i unplug the tv and plug it back in and the "trap switch" is taped up so it won't put the tv in "lock mode" when i plug the tv back in then i have to reset the "lock mode" or the red light on the main video board won't come on and stay on.
      • philliesfan30m
        • Aug 2013
        • 542
        faulty "trap switch" maybe?
          When you reset the trap switch do you get any screen glow, or is the screen not lit at all?
          • philliesfan30m
            • Aug 2013
            • 542
            when i reset it it glows for about 10 seconds then the relay clicks and then stops glowing. now i'm having trouble getting it out of "lock mode" i'll get it but it's just a little tricky
            • philliesfan30m
              • Aug 2013
              • 542
              when i reset it the red light on the main board goes out while the tv is on i can see what looks like maybe the service screen very faintly but i can't do anything and it shuts off then the red light on the main board stays on. is it suppose to stay on or be out and it doesn't throw any codes. i can keep trying to reset it but the same thing happens and when i unplug it and plug it back in then the light is out on the main board until i do a reset then it stays on after the tv shuts off.
                Does the TV have the serial port?
                • philliesfan30m
                  • Aug 2013
                  • 542
                  yeah do you want me to try and run it through a tv or laptop etc.? and see if it works that way?
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    the fan isn't working either it did for a little bit one time i don't know if that is also part of the problem but that is attached to the main video board
                    • philliesfan30m
                      • Aug 2013
                      • 542
                      i don't get it. if i reset the tv the fan won't come on but if i take the plug for the "trap switch" out and jumper the wires together the fan starts up but if i have the jumper there and reset it he fan won't come on when it should?
                        Try entering service mode? I think it involves holding the INPUT or MENU key while you power the set up. It's possible that it has an existing fault that hasn't been cleared.
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          i thought that was what i was doing when i hit the display then left,up,left,right,then power and it turns off the red light on the main video board and the screen come on very faint and i can't tell what it says then the glow from the screen shuts off after i hear a relay click
                          • philliesfan30m
                            • Aug 2013
                            • 542
                            if i disconnected the x drive board and tried to enter service mode the blue power button went off and i got 11 blinking red lights then a pause and 11 more continued. and when i only had the y drive board disconnected i got a 3 red blink error without a blue power light.what can i do? and on the x drive board it has a connector for a + 60v and when i measure it i only get .9 volts? at all the other connection i get what the board reads any help?
                              Does power supply produce a Vd of 60V or closer to 70V? Perhaps missing Vd is triggering shut down.
                              • philliesfan30m
                                • Aug 2013
                                • 542
                                vd? and pin 3 from the power supply to the main board is suppose to be a N.C. (relay) that reads 3.5v but i get 0v when i checked it or is it suppose to be normally closed? i am tired been up all night trying to figure it out. i get only .9v at the power supply connector too when i am suppose to get 60v. here is the complete manual i have to figure out why i'm not getting the right voltage.
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  i just reset it and when it tried to go into service mode i checked the voltage and it got approx. 40volts but then i kept dropping until it is now around .9volts and doesn't seem to go any lower than that.
                                    Vd may be called Vad, Vda or Va on this panel.
                                    • philliesfan30m
                                      • Aug 2013
                                      • 542
                                      u mean vadr? which is suppose to be 60v on the power supply? there are 2 pins that are suppose to read 60v going to the x main and 2 pins going to the y drive they all read .9 volts and were higher but were gradually dropping like noted in my previous post that was what i was checking and it was dropping but won't go any lower than around .9 volts
                                        Yes, maybe Vadr. Check Vadr on power supply, is it stable? How long does it stay? Then check Vadr on X-main.
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
                                        • pixelcap
                                          Pioneer Plasma 111FD To Solder or Not to Solder.
                                          by pixelcap
                                          Hello out there in Badcap land.
                                          I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
                                          are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
                                          Thank you
                                          Pixelcap...
                                          03-08-2025, 07:10 PM
                                        • alltvrepairs
                                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                          by alltvrepairs
                                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                          Any one met this problem in the past?...
                                          10-08-2025, 07:34 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • bcstedt
                                          Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                          by bcstedt
                                          Just starting to crack into this one and wanted to get the ball rolling.
                                          At power on (plug in), power light on, relays click, repeat (sometimes)
                                          After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                          Removed Y-Main for inspection and testing
                                          This pic from:
                                          PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                          12-15-2023, 10:30 AM
