I have an issue with voltage coming out of power supply. vs is a steady 195.6 requires 190 va 61.2 this is steady it will start dropping fast at .508 it will click off then it builds back up to 61.2 and repeats the same thing .any ideas thanks:
toshiba pdp50x3 power supply issue
Re: toshiba pdp50x3 power supply issue
Vs is a little high, can be adjusted down. Are both Vs and Va dropping out or are they good?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Vs at 211V? Sounds like over-voltage check. Maybe it will do that with no sustain boards, hard to be sure.
OK, can you post a picture of the chassis layout? Clear and in focus please.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I would first check power board for cracked solder joints and loose connections.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It was OK before?
Check all connectors.
Check all output voltages from PSU - not just Vs/Va but also 3.4V, 6V, 12V etc.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Also check AC DET voltage.
If you put the old power supply in how does it behave?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes I had done that and its the same .I also noticed that the control board lge pdp050121model50x3 led's d1 not lit d2 lit d15 lit d16 not d17 not d18 lit . if that's any help I know at one point they were all lit . also I checked the model no. with the back off label is pdp50x3 and on the outside case it is pdp50hp66 should have checked closer thanks
