So I replaced the three ic and now the tv turns on. Well it turns on and the red light blinks 3 times for about 5 sec then the blue light turns on and the red led stops blinking and turns off. The backlight turns on but seems brighter on the sides then it does the middle. And the backlight stays on for 5 seconds and turns off and then tries to turn back on immediately. But the blue light states on the whole time and q880 keeps getting hot. Does anyone know the voltages of the ic at q880 the strw-6765 I think is the model number. Cause I have no clue where to check. I disconnected the inverters to look for damage but no luck.
New problem 42hl196
Tags: None
Re: New problem 42hl196
Did you put on enough heat sink compound when you install the new IC? Toyical VCC for the STW6765 is around 18~19V range, see spec attached. Is the 12V out put steady?
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I put quite a bit on there and it's coming out the sides of it. And thanks for the voltage info. I'm wondering if its the connection of the regulator or the seine board going bad. Someone else had the same problem but I never heard if replacing the seine board fixed itComment
I will be working on that TV and the power supply board tomorrow, I took those pictures last week.Never stop learning
So what did you just put some resistors of the power supply. What value are those resistors.Comment
The typical 1 k resistors. I am also trying to figure out why that IC gets so hot, I did not have a chance to check the temp yet.Last edited by budm; 09-03-2013, 06:35 PM.Never stop learning
I tried the resistor thing you did but it didn't change anything. It still does the same thing. Tv blinks red lights for 30sec then blue light comes on with backlight which looks kinda dark in the middle then screen shuts off then comes back on a couple seconds laterComment
You use the resistors to test the power supply by itself, not connected to the other board.Never stop learning
Lol oops. I'm like stumped on this one cause I have replaced the regulators and got it to turn on but I don't know why that one regulator still gets hot.Comment
The 12V SMPS IC does run too hot to touch, mine is still running.Never stop learning
yea the one regulator thats the most common to go bad the 6765 one heats up and right when it gets to hot to touch the tv turns off and then waits like 3 sec to turn back on.Comment
So I finally fixed the tv. I had to redo the one regulator solder connections and the cause of the blue light and then the back light turning on then back off and repeating was the seine board. I don't know what in it was bad but I just bought a replacement tossed it in and fired right up. It did the diag 3 red light flash only initially after plugging in the tv and then worked like normal.Comment
I was just reading through this thread. I worry when I read that the temp of the regulator seems very high and you had a lead that needed to be resoldered. What's the chances that the temp is high enough to melt the solder?Comment
I think the reason the temp was so high because it was probably working extra hard to send the voltage to the seine board which was faulty. I will check the reg later today to see if it still gets hot or not.Comment
And the reason I had to redo the soldering again was because the whole time I was troubleshooting the backlight thig I thought it was te reg causing it. Like maybe I didn't do a good solder job cause it was one of my first component solder jobs so I kept redoing it and it wasn't the problem the whole time.Comment
So I tested the tv and left it on for about a hour and a half and heard a huge pop and tv was off giving 3 red blinking lights. I looked at the connection of the 6765 and one of the solder joints I guess got hot and melted and touched the one next to it. Do u think its fried the strw6765. I'm so frustrated now with this power board. It would be nice to start again with a fresh one but you can't find them anywhere.Comment
So I bought a power supply off ebay and got it and plugged it in and it fired right up cause it said it came out of a working tv w/cracked screen of course. It worked fine for about 30min then shut off. I went and felt the heat sink on the strw6765 and it's blazing hot. And I touchΓ© the resistors above it and they are hot but not burning hot. And I touched the other two big heat sinks with mosfets on them an they are warm but not burning. I do not understand what the problem with this is. Why is it running so hot. And I'm sure that's why it shut down.Comment
As a suggestion, I'd just check the various diodes that form part of the circuitry around that regulating device. You might have to lift one leg to accurately check. Bud is far more knowledgeable than me, but often these diodes perform a 'snubbing' function to prevent high frequency oscillations and the like, and if the diode has failed then the device can overheat although will initially function.Comment
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... - Loading...
