baird 42 flickering strobing wont start up
  • notallbad
    • Oct 2012
    • 1190
    Re: baird 42 flickering strobing wont start up
    No probs, check the last couple of Posts
    OK, no inverter connected, same voltage, but noise?
    • wreksta
      • Aug 2013
      • 508
      • england
      #102
      mate do you think it could be one of the caps under the heatsink would this cause the problem
      on a side not mate if was all connected I get the spike noise when the lights start to strobe this is intime with the clicking surge noise if inverter disconnected I still get same nois just no flashing do you know what I mean now so something stopping correct voltages going to all 3 connectors on psu
      • wreksta
        • Aug 2013
        • 508
        • england
        #103
        yes still get that surging buzz noise
        • notallbad
          • Oct 2012
          • 1190
          One wire connects to outer shell of bulb 1, then join the end connection of bulb 1 to the outer shell of bulb 2, then connect another wire to the end connection of bulb 2. You will then have two wire ends.
          One connects to 24v the other to gnd, on the inverter connector on the PS b/d with the connector disconnected from the inverter.
          Budm has a guide for doing this somewhere on here.
          • notallbad
            • Oct 2012
            • 1190
            OK, check the 24v inverter output as above with car bulbs, they should glow nice and bright steadily.
            • wreksta
              • Aug 2013
              • 508
              • england
              #106
              mate I don't understand the bulbs fire they just strobe the problem is with psu as I still get the surging without inverter connected
              im going to change those caps
              all im saying is there never enough voltage carried to the psu av 'inverter'auido connectors the spike surge fluxiates the voltage from low to high when I stop hearing the spiking noise the voltage drop way below to 00.2 etc
              • notallbad
                • Oct 2012
                • 1190
                Changing all the caps is never a bad idea and may solve your issue, quick, cheap and easy to replace.
                I see where your coming from, its not only the 24v inverter but also the audio 24v and main b/d volts which would most likely indicate the PS b/d but you had a steady volt reading on the filter cap powered up with no loads connected, so by connecting a load to the inverter output would eliminate a bad inverter or 24v inverter rail possibly.
                • notallbad
                  • Oct 2012
                  • 1190
                  You could with a resistor force the inverter board on to light up the backlights without the main b/d connected too.
                  Aha , just read your Post #102
                  • notallbad
                    • Oct 2012
                    • 1190
                    I think the problem is further back than from those caps, refer back to Toms posts, doesnt seem to be the PFC circuitry but regulation.
                    • wreksta
                      • Aug 2013
                      • 508
                      • england
                      #110
                      any other ideas before removing these caps is there any way to test them with a esr meter the noise the psu makes sound like its coming from 1 of the transformers on the left of the psu theres 2 at same location how to determine that
                      • notallbad
                        • Oct 2012
                        • 1190
                        An ESR meter is certainly an invaluable tool, they can be used in-circuit (No power to the board) with experience however most caps will need to be removed to test conclusively so having removed them you may as well replace. A DMM can be used to check whether a cap is short cct or not, when a cap completely fails it is most likely short cct as opposed to open cct like a resistor totally failing. But then this does not help if it is only partially failing.
                        An audio clip of the noise your getting may help.
                        Usually xformers/inductors making a noise is created by other factors causing it, not necessarily the xformer itself, so I have found out. i.e diodes, xsistors etc
                        This is with NO POWER going to the board!!!
                        You could check the diodes, DMM has a line with an arrow through it, at the bottom to the right on yours. With probes one way the DMM should give no reading, connected the other way around you should get a reading which varies depending on the type of diode under test. But as long as you do not get a reading at all in one direction is a good sign. The actual reading that you do get is not in fact meaningful just an indication. You can do this in-circuit but remember if theres a short on the circuit it may not necessarily be the diode but another component in the same part of the cct so you'd have to remove one leg of the diode and test again.
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          #112
                          doing this give me no reading at all if I put my mm on 60vdc I was getting 1558 or 15.8 any other ideas
                          • notallbad
                            • Oct 2012
                            • 1190
                            There should NOT be mains power connected - just to be sure.
                            Across caps or diodes?
                            Dmm should be on ohm range for caps and diode setting for urm diodes.
                            However, with the dmm set to a volt range and probes across a cap you should see the dmm read a voltage that gradually decreases and on an ohm setting see the resistance gradually increase.
                            Try it with a cap out of circuit to see what happens but don't use a large cap which is 'charged', could damage your Dmm on the ohm setting.
                            Start with the lowest setting in the volt and ohm ranges and increase if no proper reading.
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              #114
                              Update replaced the power supply board
                              and guess what still the same flashing strobes not turning on where to start now other ways to test inverter with multimeter
                              don't have any car bulbs
                                Well poundland have got two 65W headlamps for £1 (get two packs) so I'd check there, they are pretty useful for testing power supplies, do not rule out possibility that your new power supply is bad, as all the tests showed it was not working well.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #116
                                  you may also want to try heating the whole psu up with a hair dryer for about 4 mins they see if you still have the same issue with it flashing also whats the full model number of the tv from the sticker on the back of the set.
                                  • reessi
                                    ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                    by reessi
                                    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                    They are black on the right and gradually fade to nothing on the far left.
                                    They start either after 5 mins or up to 2 hours after so annoying for testing.
                                    They flicker continuously very fast! With a slight pause milli-second every second.
                                    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                    I tested each half by removing the first the left flex from...
                                    06-03-2025, 09:58 AM
                                  • howardc64
                                    UN65TU7000 strobing / flicker
                                    by howardc64
                                    Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                                    Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                                    Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                                    03-26-2023, 04:37 PM
                                  • zuehls
                                    samsung flashing/flickering/strobing
                                    by zuehls
                                    I have Samsung UN55ES6150 TS01 tv that has a backlight that flashes/flickers/strobes. I have disconnected the cable between main board and power supply and the backlight stops flashing/flickering/strobing. I checked the voltage on power supply (BN44-00503a) CNL802 pin 4 (R-) and pin 6 (l+) and both are 141v each. It is also steady. If I reattach the cable between main board and power supply and plug in the tv it is steady and good at 141v for about 5-7 seconds and then the screen starts flickering/flashing/strobing and the voltage starts bouncing between 138-142. What is correct voltages on CNL802?...
                                    05-11-2020, 03:34 PM
                                  • DrvLikHell
                                    Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                    by DrvLikHell
                                    Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                    The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                    07-05-2024, 02:54 AM
                                  • Jaysean
                                    Acer VN7-591G-70RT Display Flickering
                                    by Jaysean
                                    Hello Badcaps coummunity hope you all are having a bless day,
                                    Hope I didn't post it wrong kinda new at forum site rules and tradition
                                    So I'm dealing with screen flickering problem on my laptop.
                                    I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                    so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                    [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                    [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                    10-27-2023, 10:22 AM
