Samsung LN46A650 backlight turns off after a while
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung LN46A650 backlight turns off after a while
    Any other ideas?
    • tibimakai
      • Jan 2012
      • 3680
      I had power supply boards from other Samsung TVs and I had an idea, how about using one of those if they match up.
      I have found one which had the same exact connectors and all the pins matched up too.
      It may have been from a 46A540(530)?!, or a 52A550.
      The TV powered up and it worked. I have left it to run over night. In the morning the backlight it was off again, so it's not the power supply.
      One thing I'm keep forgetting to do, is to check the screen with a flashlight. Next time. Later on, I will start it up again and I will let you know about this.
      Any other ideas, what should I check?
      • kalemaroni
        Samsung QE50Q60AAUXXH turns off as soon as backlight turns on
        by kalemaroni
        Plugging the power in will turn on the backlight after about 5 seconds and then immediately shuts down.
        If I unplug either of the two cables with the yellow outline in the picture the backlight stays on and the startup sound plays but no image. Any ideas how to proceed with this please?
        07-16-2025, 04:53 AM
        09-07-2024, 05:50 AM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
