tcon replacement for lg 42lg3000
  • wreksta
    • Aug 2013
    • 508
    • england
    I need some help I have a friends tv here its a lg 42lg3000
    but the tcon available I need to replace with is not the same
    this one I have in it that's bad
    http://www.aliexpress.com/store/prod...620659978.html
    but searching on ebay brings this one up for the tv vbut the bibbon connectors are to small and screw placement wrong
    http://www.ebay.co.uk/itm/6870C-0204...item3f25e14ae5
    Re: tcon replacement for lg 42lg3000
    You need to match the board exactly to what you currently have.
    • wreksta
      • Aug 2013
      • 508
      • england
      http://www.ebay.co.uk/itm/LCD-TV-TCO...item19e0e814a8
      will this work
        Is it exactly the same as what you have already?
        • wreksta
          • Aug 2013
          • 508
          • england
          looks the same mate
          no difference in visual
            Part # the same?
            If so probably will be OK.
            • wreksta
              • Aug 2013
              • 508
              • england
              nah not the same mate but the board that was in the tv in the first place I suspect was the wrong one so what im asking is where to get it
                You can't be sure, but if the panel number it is made for matches the one on the LCD Panel (e.g. AU Optronics LC42W8XAA) then it should be fine, otherwise you cannot be sure and will have to take a chance.
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  ok thanks tom look like ill have to use one of those cheap auo tcons
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                    the panel its for is a t420XW01
                    • notallbad
                      • Oct 2012
                      • 1190
                      Hi
                      If you want I shall check to see if I have one that matches yours, it is working, came from a broken panel tv.
                      Let me know how much you find one for and I shall match there price and postage costs, though may be able to better it if they are costly.
                      • notallbad
                        • Oct 2012
                        • 1190
                        Hi, yes I have one its a T420XW01 V4
                        Came from a Sharp LC-42SD1E
                        So will look like this one:
                        http://www.ebay.co.uk/itm/LVDS-BOARD...item4ac1f224fd
                        • wreksta
                          • Aug 2013
                          • 508
                          • england
                          hi mate not the right one sorry
                          • notallbad
                            • Oct 2012
                            • 1190
                            No problem just thought it would be quicker and cheaper for you and it would be a confirmed known working one, not an ebay 'working' board, so they say.
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • spartantravis
                              46pfl9707 : TCON replacement Region specific or anything?
                              by spartantravis
                              Hi guys
                              I ran into some trouble with my Phillips 46PFL9707 TV and isolated the problem down to the TCON board. I eventually saved up enough money to buy a replacement one from ICCFL.com but when it arrived and I inserted it, all I got was a black screen when I switched on the TV. Even the old broken one produced some type of screen distortions when it was there.
                              Both of the TCON boards are CPWBK 4920TP RUNTK and look identical but they have a slightly different code written on them (ZE 118A127 is written on the old one) while the new one has ZH -something written...
                              07-09-2021, 04:11 AM
                            • alltvrepairs
                              Lg TCon test pins for screen test
                              by alltvrepairs
                              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                              Appreciate your help....
                              06-13-2025, 06:33 AM
                            • angelos
                              TCON and self diagnosis!
                              by angelos
                              Hi Guys.
                              I have experienced something rather unique and need to find out by the forum what to make of it.
                              I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal...
                              09-19-2022, 03:05 AM
