haier l32k1
  • willyam1
    • Feb 2012
    • 112
    • israel
    haier l32k1
    need service to this tv chassis MST6M69GL.
    problem is.
    no data no screen no pic ther is backlight.
    12v not apply to the lvds cabel all voltage ok the smd fet not recive the command to transfer the 12v.
    willyam
  • willyam1
    • Feb 2012
    • 112
    • israel
    Re: haier l32k1
    hi.
    also find no signals in other pin of lvds cabel.
    stary checking all reg and pwm voltage all of them ok 5v 3.3 2.5 and 1.2v in the last one foind that the resistance in this voltage is 38 ohm its seems to me that its too low and I think this is fading the big micro vdd core voltage if so maybe need to by another board.
    willyam
      Re: haier l32k1
      is it HL32K1?
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: haier l32k1
        no its diffrent.
        mine is using another micro mst6mgl-lf.
        willyam
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
        • lpraderi
          Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
          by lpraderi
          Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
          In some cases to use LVDS screen PCB use converter IC RTD2132/6
          Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
          at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
          Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
          11-25-2023, 09:31 AM
        • TCCTech
          HP Elitebook LVDS port
          by TCCTech
          Hi all, I appreciate any help at all on this I have an HP Elitebook 840 a customer spilled tea on it and it shorted/melted the LVDS port I found the schematic here
          file:///E:/Users/BBB/Downloads/HP%20EliteBook%20840%20-%20ZBOOK%2014%206050A2559101-MB-AX1%20COMET%20DIS%20SI2%20Schematics.pdf
          But i can not find the part number for the LVDS port if anyone knows where I can get a LVDS port I would appreciate it. Every time I google it I get lots of LVDS cables but not the port/connector.
          Thank you in advanced...
          09-02-2022, 05:18 PM
        • Scincidae
          UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
          by Scincidae
          I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
          I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
          04-24-2022, 06:00 PM
        • ResoluteHawk
          Connecting an LVDS/eDP cable into a live motherboard
          by ResoluteHawk
          Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
          Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
          I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
          08-04-2025, 04:39 PM
