Baird x32dtv
  • vinceroger69
    • Mar 2012
    • 6714
    Baird x32dtv
    hi just picked one of these up from my local freecycle site the problem is the psu has had a major short on and blown some surface mount ics and some surface mount resistors and others surface mount capacitors so a lot of parts to replace as main fuse also shattered so probably bridge rectifier as well so i really need another psu the part number on it are
    PHIHONG
    MODEL PSM210-417A-R
    OUTPUT VOLTAGES ARE
    5.VOLT 0.8 AMP
    12V. VOLT 3 AMP
    16.5 VOLT 2 AMP (SEEMS ODD AS WHEN I FOLLOW THE WIRE BACK TO THE MAIN BOARD ITS GOT 12.VOLT STAMPED ON THE CONNECTOR (DOES VADJ)
    24 VOLT 6 AMP
    i have found one in china thats about £40.00 just wondered if any one had a link to the universal lcd psus i may then be able to modify to fit.
    Re: Baird x32dtv
    Unfortunately the 16.5V, for the audio, is going to be difficult to retro-fit.
    There is a chance you can take, say, a Vestel 17PW20, and feed the audio with 12V. This will mean that the audio output won't be able to go as loud as it used to, and it will probably distort near the maximum output.
    • vinceroger69
      • Mar 2012
      • 6714
      Re: Baird x32dtv
      thanks tom i understand what your saying it seems funny the connector has 16.5 volts stamped on the psu unit says on connector vadj 2pis and ground the other 2 pins but follow the wire to the main board it says vadj 2 pins 12 v 2 pins ground this is the sort of thing i was thinking of? http://www.alibaba.com/product-gs/69...er_Supply.html
        Re: Baird x32dtv
        I don't know if I'd trust that... looks pretty poor build quality
        • vinceroger69
          • Mar 2012
          • 6714
          Re: Baird x32dtv
          any idea tom what size the board your thinking of in size as these are small 7 inch by 5 and a quarter cheers as there is not much room inside these sets do you know if these are freeview? also if its to old i may just part it out pity though as has stand and remote as well reasonable condition but cant see resale being much.
          tom is there a psu diagram about for the original psu? to see whats blown as a small ic has blown the top of unreadable
          looks like i can use 12 volt instead of 16.5
          http://www.tv.quuq.org/forum/index.php?topic=6330.0
            Re: Baird x32dtv
            I don't know, only solution may be to repair it. No schematic as far as I can tell. If you can find the part # of the burnt IC, then it is probably that + PFC FET + 450V capacitor. (Bad 450V capacitor will cause PFC FET and IC to burn.)
            • vinceroger69
              • Mar 2012
              • 6714
              Re: Baird x32dtv
              reading that link i can use one of these with a small mod to connectors just cant seem to find dc output specs of it?
              http://www.ebay.co.uk/itm/POWER-SUPP...item3cd3c6657d
              edit just found this ic 101 is blown
              • vinceroger69
                • Mar 2012
                • 6714
                Re: Baird x32dtv
                just removed the cover the fuse is gone ic 101 is blown any idea what a 7503 surface mount is looks like a large resistor got 2 by the blown ic cant get a reading at all.
                edit!!!! you was spot on tom was the large 450v cap reads 00000 on my cap meter no uf reading at all and yes did test a good cap to make sure meter was ok.
                tom can you tell me how to test and what meter settings to test this ic P1014AP06 standby ic? just want to check if possible its ok before i order the blown ic and capacitor.
                  Re: Baird x32dtv
                  Can you provide a picture of the bottom of the board?
                  Standby IC -- check between Vcc and GND of IC, look at datasheet for pin diagram.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Re: Baird x32dtv
                    will get a picture soon as i can measured from vcc and gnd of ic no reading tried 200 ohm 2k and 200k does this seem ok?
                    looks like q102 20N60C3 maybe faulty short circuit on 2 legs leads tested both ways
                      Re: Baird x32dtv
                      Yes, it's probably OK.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Re: Baird x32dtv
                        tom can you look at my edit please shot circuit both ways pins 2/3 and the 3/2 on diode test it has a insulation washer on the heatsink on this ic.
                          Re: Baird x32dtv
                          Also check DRAIN to GND, and DRAIN to VCC on it.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Re: Baird x32dtv
                            on ohms reading tom no reading at all on both your tests so this should be ok?
                            what do you think of these readings? looks like q102 20N60C3 maybe faulty short circuit on 2 legs leads tested both ways pins 2/3 and the 3/2 on diode test it has a insulation washer on the heatsink on this ic. data sheet in post 10 cheers tom. the last thing i am not sure is what a 7503 is its like a small rectangular resistor 2 of them by the ic thats blown cant seem to get a reading from them.
                              Re: Baird x32dtv
                              When you get a picture of the area, I can figure out the problems.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Re: Baird x32dtv
                                cheers tom cameras on charge might wait till tomorrow in good sunlight.
                                  Re: Baird x32dtv
                                  It seems unlikely that a 32" LCD TV would use a 45A IGBT. That is something you would put in an industrial motor drive or 1000W+ power supply. Are you sure about the part #?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Re: Baird x32dtv
                                    q102 in this parts list
                                      Re: Baird x32dtv
                                      More likely to be
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Re: Baird x32dtv
                                        More likely to be
                                        more than likely yes this out of circuit is short on diode test pins 2 and 3 both directions is this good or bad?
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • gabri2211
                                          external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
                                          by gabri2211
                                          Hi to all 😎
                                          I'm looking for any useful information to repair this interface (I have attached the image).
                                          On this board I read E3215-1215A_4D.
                                          This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
                                          If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
                                          in particular...
                                          11-12-2024, 08:08 PM
                                          Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                                          by sam_sam_sam
                                          I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                                          I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                                          I used a four USB outlet and electrical plate that is made for...
                                          08-03-2024, 07:54 PM
                                          I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
                                          by sam_sam_sam
                                          Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
                                          https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
                                          I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
                                          08-03-2024, 02:54 PM
                                          I am in need of a 21 volt switching power supply with at least 5 amp capacity
                                          by sam_sam_sam
                                          I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
                                          I would rather not have to use a buck converter to get the voltage that I need
                                          So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
                                          I googled for a 21 volt switching power supply and did not find very much information for switching power supply...
                                          02-19-2023, 05:47 PM
